Clonck comes up with gray background in transparency on boot
    matt3
    Posts: 785 from 2004/2/10
    Issue with newer versions of MOS on my PB in my wbstartup.
    With the tranparency setting on it has a grey backround until I pickup and move the clock, than it grabs the background perfectly.
    I tried turning on and off all the buffer and cpu settings.
    If I don't load it in my wbstartup and just click on it after it boots, it works perfectly.
    When I used it with my Peg II with earlier MOS versions it also worked perfectly.
    Any ideas?
  • »20.01.14 - 09:28
    Posts: 3337 from 2003/3/5
    My guess would be that Clonk does not handle alpha transparency and instead resorts to hacks that are timing dependent.
  • »20.01.14 - 09:48
    Posts: 12572 from 2003/5/22
    Could be the same issue as described there:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7198&forum=9
  • »20.01.14 - 09:55
