General e-uae questions
    redrumloa
    Posts: 1424 from 2003/4/13
    The other thread title sounds G5 specific, so I'll start a general one. Here are some questions.
    1) Where do I find make_hdf? It is mentioned in the readme but not included, plus google is not my friend :-( It is a pain to walk across the house to my PC.
    2) Anyone ever made a Warp3d driver for E-UAE like WinUAE has? I'm sure I know the answer, but with JIT coming I'd figure I'd ask :-D
    I may ask other questions here, thanks!
  • »10.01.14 - 00:27
    redrumloa
    Hello? McFly?
    Do I have body odor here or something?
  • »12.01.14 - 14:58
    You funny, Red.
    Couldn't smell you this far away anyway (I hope).
    Anyone?
    I'd like an answer for this too file away (although if I want to run UAE, I do it under Windows).
  • »12.01.14 - 16:07
  • vox
    vox
    Posts: 541 from 2003/11/24
    a) Well if try creating it with AmigaKit on Linux or ... Windows, if you must.
    b) No, I believe not. Please someone prove me wrong.
    I am intersted to know how much UAE performance has improved with JIT beta for MOS especially on lower end machines that run MorphOS?
    Lame PC with AmiKit XE
  • »12.01.14 - 17:01
    Norbi
    Posts: 99 from 2004/6/19
    This is easy.
    You create a file so what you need (http://aminet.net/package/util/cli/mkfile), then you format it on the emulator
  • »13.01.14 - 05:31
    redrumloa
    Norbi wrote:
    This is easy.
    Looks good, I will try it out. Thanks! I'm still curious why the MorphOS specific part of the readme mentions a tool that apparently doesn't exist. At least this tool you mention should work, at least the 68k version.
  • »13.01.14 - 16:34
    Norbi
    http://aminet.net/package/dev/c/emptyhandler-morphos
  • »13.01.14 - 18:02
    redrumloa
    Ok, so I made a configuration for classic 3.1 system with P96 using the e-uae.g5-sdl executable. Everything looks and works pretty good so far, with the exception of AmigaAmp which crashes.
    Any thoughts why? Is it because everything is set to fast and AmigaAmp relies on chipset timing?
  • »15.01.14 - 18:08
