Unzip / Unrar as context menu commands
    Cool_amigaN
    Posts: 776 from 2011/11/30
    Hey all, here's a simple question which I have trouble answering: how is it possible to add a context menu command (similar to Ambient's lha extract) to unzip .zip, .rar and .7zip files? Is there a specific program that handles all zip file types? I am mostly interested for the first two (zip and rar) but would also like to know about 7zip as well.
    And happy holidays everybody!
  • »30.12.13 - 06:28
    Posts: 12530 from 2003/5/22
    I recommend using the XAD system, i.e. the XADUnFile command. For ZIP files you'd do it as follows (adaption of my recent German posting, so GUI element designations may be off):
    1. double-click "Settings" -> "Ambient" -> "File types" -> "application" -> "zip"
    2. click "Add"
    3. enter a "Name:" (e.g. "decompress", "extract" or similar)
    4. set "Event type" to "Menu"
    5. activate "Work directory is source"
    6. click "Add"
    7. set "Type" to "AmigaDOS"
    8. enter "MOSSYS:C/xadunfile %sp %S" as "Command"
    9. click "Change"
    10. click "Ok"
    11. click "Save"
  • »30.12.13 - 07:31
    Cool_amigaN
    Thank you so much! Will try it once I get back home. Imho, this should be also preconfigured on Papi's awesome pack :)
    Btw, you know how to do it for rar and 7zip as well? I am exchanging lots of files with my PC and I would prefer to perform unpacking at MorphOS.
    [ Edited by Cool_amigaN 30.12.2013 - 10:52 ]
  • »30.12.13 - 07:52
    It should work the same using XAD for RAR and 7ZIP (with "rar" or "7zip" instead of "zip" in step #1, of course), except that you need to install http://aminet.net/package/util/arc/xad_7z (m68k binary) for 7ZIP and maybe http://aminet.net/package/util/arc/xad_rar (m68k binary)* for RAR. I'm not in front of my MorphOS machine now so cannot check if RAR is already covered by MorphOS' XAD system (check with XADLibInfo command).
    * Edit: http://fabportnawak.free.fr/misc/xad_rar.lha has a MorphOS-native client
    [ Edited by Andreas_Wolf 01.01.2014 - 16:04 ]
  • »30.12.13 - 08:36
    Cool_amigaN
    @Andreas_Wolf
    Thanks, it worked as you told me for the zip archives :)
    The UnRAR context command was set as pre-default so there was no need to mess with it.
    Will try the 7z solution you proposed me as well once I get the time. Btw, I got really good times in unpacking rather big archives of zip and rar formats under MorphOS yesterday.
    And one last thing, if anybody is reading this, please make it the default behavior for MorphOS and/or Pack Ultimate since lha, zip, rar and 7zip files are very very common.
  • »31.12.13 - 05:59
    Jupp3
    Posts: 1193 from 2003/2/24
    Andreas_Wolf,
    maybe http://aminet.net/package/util/arc/xad_rar (m68k binary) for RAR.
    iirc someone (Fab?) released MorphOS native rar extractor for xad long ago.
    Note: I think xad already comes with "a" rar extractor. Only a very outdated one that can only extract REALLY old archives, and is practically useless (but might fool you to think that "it should work")
  • »31.12.13 - 08:18
    Indeed. It's http://fabportnawak.free.fr/misc/xad_rar.lha released 4 years ago.
  • »01.01.14 - 13:53
