Requesting MUI Builder for MOS.
    liquidbit
    Posts: 408 from 2003/10/12
    Does anybody knows where I can find MUI Builder for MOS?
    Can I use the one from aminet?
  • »05.02.04 - 06:10
    liquidbit
    do you have an example?
  • »05.02.04 - 08:04
    realstar
    Posts: 298 from 2003/2/24
    MUI Builder works fine on MorphOS and is
    good to learn the basics. I would also
    read the autodocs, "libraries/mui.h" and
    check the example programs included in
    the SDK.
  • »05.02.04 - 08:34
    liquidbit
    thanks realstar
  • »05.02.04 - 13:17
    Kaczus
    Posts: 199 from 2003/9/6
    Lately I've finished adaptate MUI++ for MOS... unfortunately i
    must do same changes in api, but You can test it: http://kaczus.republika.pl/2b_MUIPlus_MOS.lha
    Docs is not finished yet...
    Kaczus/BlaBla & AUG-Lodz Happy Pegasos User
  • »07.02.04 - 07:18
    tokai
    Posts: 1289 from 2003/2/25
    @lucky:
    because that I said the builder is useless... it's much better to code own properly code and learn the things alone than to modify (maybe bad) source from others.
    Better spend some time in learning to code than to think some builder can help you. That's my opinion.
    For same reason I also avoid WYSIWYG-HTML editors. :-)
  • »07.02.04 - 07:50
