NetSurf
    Posts: 1521 from 2003/2/24
    Ok, I figured it out. There is a bug in WB arg handling and when there is an icon NetSurf attempts to load its own executable to a browser. But there is another bug in handling of local files which causes NS to hang.
    So for now get rid of that icon. Will be fixed in the next release.
  • »18.01.09 - 20:33
    MorphDelf
    Posts: 274 from 2004/2/20
    Thanks for the NetSurf port itix. Very good!
  • »19.01.09 - 18:13
    xyphoid
    Posts: 870 from 2008/7/11
    Having the same above mentioned hanging
    what exactly do I delete or replace? to
    get it going?(What/Where netsurf.info?)
    Posted with Sputnik
    [ Edited by xyphoid on 2009/1/19 19:02 ]
  • »19.01.09 - 22:01
    @xyphoid
    There is file called "NetSurf.info" in the NetSurf directory. Delete it either from the shell or from Ambient: switch to lister mode and delete NetSurf.info file (see here).
  • »22.01.09 - 21:27
    xyphoid
    still loads, then disappears, a.org, morph.zone
  • »23.01.09 - 20:50
    MorphDelf
    If you still have problems with getting NetSurf showing fonts. You need a _ttf font called Times New Roman Latin2 or NetSurf wont show text. Once you have done this, even starting NetSurf from its icon works. Also remember to download database.engine which itix links on first page.
    Good luck with the surfing!
    [ Edited by MorphDelf on 2009/1/25 3:50 ]
  • »25.01.09 - 00:49
    DJBase
    Posts: 745 from 2003/4/6
    Any chance for a MOS 1.4 version? Might be usefull for PUP users.
  • »25.01.09 - 08:43
    Posts: 12543 from 2003/5/22
    There's no need to download ttengine.database (not "database.engine") anymore since it's part of the NetSurf archive dating from one week ago which itix mentions on the second page.
  • »25.01.09 - 08:54
    @DJBase
    There probably is 1.x compatible version in the future.
  • »25.01.09 - 21:32
    xyphoid
    I'll wait for the next update from itix :-)
  • »26.01.09 - 21:34
    SKOLMAN_MWS
    Posts: 107 from 2006/10/24
    I tried run version 2.0 dev on MOS 2.7-3.4 but does this not work (shows the GUI and the end)
    _
  • »04.10.13 - 16:50
