Problem installing classic application in MOS 3.3
    WeiXing3D
    Posts: 327 from 2012/6/13
    I'm trying to install Pagestream 3 in my MorphOS 3.3 system but the installation is being done in a partition that I don't even have in my system.
    How can I pre-determine in which partition I want to install?
    This is what I'm doing:
    1. Install and mounted all 6 adf images with FileImageCtrl
    2. Launch Installer with install-pagestream in disk image 1
    3. Select Install for real
    4. Proceed
    At the end of installation a text script opens showing all the features included in Pagestream. And the installation says it was successful but points to a partition that I don't have.
    Thanks in advance for any help.
  • »01.10.13 - 18:32
  • k8o
    k8o
    Posts: 57 from 2013/5/29
    Are you sure its not pointing to an assign that it made and not a partition?
    What exactly does it say?
  • »01.10.13 - 19:02
    WeiXing3D
    UPDATE: I managed to install using a different set of adf images. Pagestream 3.2 is now working or at least it looks like it is working.
    I opened the tutorial Newsletter and it shows fine.
    Now I need to figure out how to assign the fonts to be able to use it.Could anyone refresh me on how to do this?
    [ Edited by WeiXing3D 01.10.2013 - 13:57 ]
  • »01.10.13 - 20:01
  • k8o
    k8o
    Your best bet is to run a program called SCOUT while you perform the install. Scout will show you full paths to where it is installing everything, and a whole lot more.
    UPDATE: I see you found a fix, well done :)
    [ Edited by k8o 03.10.2013 - 15:45 ]
  • »03.10.13 - 14:45
