Posts: 1619 from 2012/11/9
XDelusion wrote:
No one?
I haven't used PPaint or DigiBooster on MorphOS 3.2 at the moment, but Final Writer also exhibits some weird behaviour when it's run under MorphOS - having a dark/black background so you can't see any text you type unless you fiddle quite a bit with the preferences, what is happening there I'm not sure, and whether it can be fixed is another matter, but Wordworth 6 seems to work OK for me.
I can't get PageStream 4 to work either as the fonts are just not recognised, something weird is going on there also I feel. The program starts OK. and the menus all show - except for the TYPE menu, which affects TEXT, so not really surprising if you can't get the fonts to work then it's logical that the system won't allow you to enter that menu - but it's weird, and I wish it was fixed, as that's one of my favourite programs from the Amiga days, and there's nothing that comes close to it on MorphOS at the moment, which is a pity.
