EUAE and classic Amiga emulation
    aszu
    Posts: 14 from 2013/6/15
    Hi, i have managed to install and start EUAE. It starts with a boot screen. Where and how do i mount adf files, please? And is it possible to open .adf file or mount it as dfx:, as some software comes in disk images, pls?
  • »21.09.13 - 12:22
    Posts: 2217 from 2003/2/24
    You can give adf as an option when you start it "-0 <file>" for df0: for example. Or while emulator is running press ctrl-alt-f1 etc to insert new adfs or dms'es into different disk drives.
    [ Edited by jPV 21.09.2013 - 21:33 ]
  • »21.09.13 - 16:32
