Printing failure
    dake
    Posts: 204 from 2007/9/14
    When I tried to print with MorphOS 3.2 I get this "Failed to initialize output device" from APDF and VPDF.
    When printing from OWB it's working fine.
    I'm using postscript and netprinter.
    One funny thing that solved my problem was when I untick the "PostScript" box in VPDF it works to print.
  • »07.06.13 - 16:47
    NewSense
    Posts: 1618 from 2012/11/9
    Try inputting PRT: into the OUTPUT field instead of PS: and that works for me, using my Mac Mini and printing via my LAN, but my printer is a HP 5M Colour LaserJet PostScript printer, so please bear that in mind.
  • »07.06.13 - 19:31
    dake
    Forgot to mention that printing with MorphOS 3.1 everything just worked fine using PS: device!
  • »08.06.13 - 09:45
    Henes
    Posts: 507 from 2003/6/14
    PS: is to print through Ghostscript.
    Even though MorphOS comes with the gs-handler and the PS DOSDriver, it does not include Ghostscript itself.
    So, by default, MorphOS is not be able to print through the PS: device. And never was, AFAIR.
    Would it be possible you have installed Ghostscript in the past and forgot about it? And it is not working anymore for some reason (f.e. MorphOS 3.2 is now installed on a different partition or something else broke Ghostscript).
    I suggest you try to re-install Ghostscript. You can use Grunch to do it very easily.
    Then printing through PS: should work again.
  • »09.06.13 - 09:10
    dake
    @Henes
    Thanks for your answer.
    I have tried to re-install Ghostscript with Grunch more than once but no luck.
    I have had Ghostscript installed a couple of years and use it on a regular basis every month.
    Two of my computers is upgraded to MorphOS 3.2 (Powerbook and Mini) from 3.1 and none of these can print pdf's from VPDF, however my girlfrends Mini MorphOS 3.1 still works with VPDF.
    With MorphOS 3.2 it works to print a webpage from OWB and use the PS: device.
    Can anyone that had Ghostscript installed before the upgrade of MorphOS 3.2 verify that printing with the use of PS: device from VPDF still works?
  • »09.06.13 - 17:45
    zukow
    Posts: 661 from 2005/2/9
    If You don't have postscript printer, please print in Turbprint mode (Postscript checkmark off). It is faster and takes less memory and ghostscript isn't required. If You have postscript printer and printing directly to NETPAR: does't work, i'll build vpdf version with debug enabled
  • »11.06.13 - 15:39
    NewSense
    I usually use PRT: as the device to send my printout to via the Ethernet/LAN on my Mac Mini as the PS: option doesn't work, and I also get an error message that the device could not be initialized - that's using the PostScript option - level 2 as I have a HP 5M Colour LaserJet printer which has either PostScript 2 or PCL printing options.
    When I 'unticked' the PostScript option and used the printer settings using TurboPrint interpreted through the PCL language it printed the document but only in Black even though the setting was set for it to print in colour. I do have Ghostscript installed.
    Any explanation for:
    1. Why printing to PRT: works using PostScript - and in colour, using the LAN/netprinter.device?
    2. Why the PS: printing option doesn't work in VPDF?
    3. Why the HP5 ColorLaserJet colour printout settings don't work using the standard print options in VPDF?
    [ Edited by NewSense 13.06.2013 - 02:53 ]
  • »11.06.13 - 22:47
    zukow
    Do not use prt: just netpar: (previously mounted). Data in PRT: goes via turboprint and in Netpar: it goes directly.
    If PS: option does't work it seems that your ghostscript installation/configuration is broken.
    does printing in color from any other program work? I always send color RGB data from VPDF to printer.device so it could be TPrint fault
  • »26.06.13 - 16:19
    dake
    @zukow
    Thanks, it works fine printing to Netpar: from VPDF.
  • »29.06.13 - 18:06
    Posts: 1390 from 2010/1/6
    @zukow:
    I've another problem with VPDF. Printing postscript directly via netprinter.device causes a blank sheet after every printed sheet. VPDF is the only prog with such a behaviour (- others like Pagestream or FinalWriter are doing correct). I can't find any prefs in VPDF to change this......
    System: PEG2, MOS3.2, HP Colorlaser 1515n / Lexmark 120n
    Mounted Net-Device (PRTN0:) for printing:
    StackSize = 4096
    Priority = 5
    GlobVec = -1
    Handler = MOSSYS:L/port-handler
    Startup = "DEVICE=netprinter.device UNIT=0 TYPE=printer"
    Printing via PS: is ok, but then I have these strange artefacts (hoizontal ghost-lines), which are well-known from many discussions about HP-Colorlaser with more than 300x300 dpi...... (which is not a problem of VPDF but of TP-drivers)
  • »30.06.13 - 05:49
    boot_wb
    Posts: 874 from 2007/4/9
    Zukow,
    If you're rebuilding vpdf is there any chance you could add a "Save" routine?
    This would allow files viewed in vpdf from OWB to be saved without having to kludge a reqestfile into the script passing the file from OWB to VPDF.
    I also have a couple of other suggestions for the wishlist if you're continuing to enhance vpdf in future, minor enhancements not worth listing here.
    Very nice and stable pdf viewer though, thankyou.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »30.06.13 - 06:51
    Posts: 1097 from 2004/9/23
    StackSize = 4096
    Priority = 5
    GlobVec = -1
    Why you use a modified version and not the version included in MorphOS and known to be working perfect?
    Just copy SYS:MorphOS/Storage/DosDrivers/NetPar to Devs:DosDrivers.
    Geit
  • »30.06.13 - 09:00
    Posts: 2220 from 2003/2/24
    Or add line "Mount NETPAR:" to your s:user-startup
  • »30.06.13 - 11:49
    Because I am useing 3 different Network-Laserprinters - therefore I need 3 different devices......
    And, by the way, I've checked this also with NETPAR-mountlist on a plain 3.2 installation - and it's absolutely the same behaviour.......
    Please notice: This problem occurs ONLY with VPDF! All other PS-programms are printing correct! Don't think that this is a problem of an incorrect mountlist.....
    geit schrieb:
    StackSize = 4096
    Priority = 5
    GlobVec = -1
    Geit
  • »30.06.13 - 17:04
    zukow
    libpoppler used in VPDF from MorphOS 3.2 has problem with generating postscript files which uses pfb fonts so some PDFs can't be printed correctly. It will be fixed in 3.3.
  • »24.07.13 - 06:17
    Flegy
    Posts: 1 from 2013/8/3
    I have the same problems with APDF and VPDF. But is not MOS 3.2 problem. With VPDF from MOS 3.1 and any older APDF (from MOS 3.0?, from MOS 3.1 not works too) is everything OK.
    [ Edited by Flegy 04.08.2013 - 01:32 ]
  • »03.08.13 - 14:21
    Tom01
    Posts: 187 from 2009/9/20
    Same here.
    Printing from Shell with Ghostscript to my Epson Stylus is still working, so it is not a Ghostscript problem.
    [ Edited by Tom01 04.08.2013 - 16:36 ]
  • »04.08.13 - 12:32
    zukow
    please, pastebin output from snoopium got during printing
  • »05.08.13 - 04:42
    Tom01
    I am getting this from Snoopium:
    http://pastebin.com/PGMnBgta
  • »05.08.13 - 09:57
    zukow
    1) select all options in snoopium except newobject
    2) make a new log
    3) print to file in VPDF (change PS: to ram:output.ps)
    4) type in shell: copy ram:output.ps to PS:
    5) check log in snoopium
  • »05.08.13 - 10:20
    Tom01
    Not much more to see:
    http://pastebin.com/3NDfdFv5
  • »05.08.13 - 11:19
    zukow
    ok, i found the bug/feature, will be fixed in next morphos release
  • »05.08.13 - 11:40
    Tom01
    That is great.
    Thank you very much.
  • »12.08.13 - 20:48
