HTML5 3D Acceleration possible on OWB?
    Doffo
    Posts: 508 from 2010/10/14
    Just was curious to see how well implemented or what exactly OWB does on HTML5. Seems that my favorite web game Runescape from 10 years ago is gonna go under transformation and run on HTML5 (No more JAVA). I don't expect a PPC to have the horse power needed to run such a game, but figured maybe it could "run" it even if it achieved an impressive 1 FPS.  8-)
    YUUUP!
  • »12.07.13 - 12:31
    Posts: 12572 from 2003/5/22
    OWB lacks WebGL support.
  • »12.07.13 - 12:47
    Doffo
    Thanks! :) That clears it up.  8-)
    YUUUP!
  • »12.07.13 - 12:51
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    To be exact, odyssey could have webgl support (and it has under Aros in some version) if tinygl implemented the required gl calls.
  • »12.07.13 - 15:41
    Posts: 2095 from 2003/6/4
    Are there many calls missing? I.e is it realistic to hope for webgl in future?
  • »12.07.13 - 17:35
    Posts: 655 from 2004/4/15
    No OpenGl Es 2.0, no Web Gl.
  • »12.07.13 - 18:38
    Jupp3
    Posts: 1193 from 2003/2/24
    Fab,
    I'd word it more like "if tinygl implemented a completely new (for tgl) concept for drawing graphics", it's far from "just missing a few OpenGL calls"
    And did I mention this also includes "a compiler for C-like language for supported GPU's?"
    Sure, there ARE already some functions in TGL that are required by WebGL, but the only "visible" one I can think of is glClear() which clears the viewport :-P
  • »14.07.13 - 14:28
    BTW The Ati R(V) 3xx chip does not support Open Gl Es 2.0. It just supports Open Gl 2.0.
  • »17.07.13 - 06:20
    Isn't OpenGL ES 2.0 basically a subset of OpenGL 2.0? If so, I guess this would mean that WebGL can work on R300 but not on R200 (OpenGL 1.4, OpenGL ES 1.0) and below.
    http://en.wikipedia.org/wiki/OpenGL_ES#OpenGL.C2.A0ES.C2.A02.0
  • »17.07.13 - 10:58
  • Fab
    Fab
    Having OpenGL ES isn't really needed. There are libraries like ANGLE that take care of wrapping to regular OpenGL. But we still need OpenGL 2.0 or so, though :)).
  • »19.07.13 - 08:12
    > Having OpenGL ES isn't really needed. [...] But we still need OpenGL 2.0 or so, though :)).
    Yes, that's what I said :-)
  • »19.07.13 - 11:05
    OpenGL Es 2.0 is a subset of OpenGl 2.0 plus some minor additional features.
    I could not find any clear statement about the capabilties of the R300 chipset.
    [ Edited by eliot 25.07.2013 - 19:24 ]
  • »25.07.13 - 16:15
