E-UAE: configuraton file for 68k demos
    noob
    Posts: 24 from 2012/10/17
    Hey guys!
    I am trying to configure E-UAE, but this is really hard to me. So I need your experience... ;-)
    Could somebody please post a configuration file? I want to use 68k-demos (aga/ecs/ocs).
    I know that the emulation without JIT-compiler is limited, but I would like to get the best out of 68k-demos.
    Thanks a lot.
    Mac mini G4 Silent-Upgrade - MorphOS 3.2 registered
  • »20.07.13 - 15:34
    hooligan
    Posts: 1948 from 2003/2/23
    I used EUAE on PS3 quite a bit and found out that finding a "one config fits all" was impossible. I know this wasn't the answer you were looking for but if someone has come up with a working compromise I'd be interested too.
  • »20.07.13 - 16:28
    Tom01
    Posts: 181 from 2009/9/20
    There are several configuration files in the conf folder.
    You start it like this: e-uae -f Conf/A500.conf
    [ Edited by Tom01 20.07.2013 - 19:40 ]
  • »20.07.13 - 18:35
    noob
    Ok, I see. I thank you so much for your help.
    I just thought that someone maybe would have a special 68k-demo config.
  • »20.07.13 - 18:45
