Problems with Samba Installation / MorphOS 3.2
    frank
    Posts: 39 from 2013/6/30
    Hi, i have problems with the samba installation ...
    (I have no idea and I'm newbie ...)
    Samba Version 3.0.4 ->
    http://aminet.net/comm/tcp/samba-3.0.4-morphos.tgz
    MorphOS Version 3.2
    --- Readme ---
    Short installation notes:
    1. Unpack the archive into your amitcp: driectory, if you are running
    another tcpip stack make a assign to the directory of your choise.
    2. Add sbin/smbd and sbin/nmbd to your inetd.conf
    3. Edit the samba configuration file smb.conf placed in samba/lib.
    In the "inetd.conf" under Env-Archive/sys/net/ I have the entry
    netbios -ssn stream tcp nowait root NetWork:samba/bin/smbd smbd
    commented out ...
    ... what should I enter in the "inetd.conf" ?
    ... in which Directory must i copy the Samba Folder ?
  • »09.07.13 - 13:55
    Posts: 2220 from 2003/2/24
    I'd ask first do you really need full Samba installation? If you only want to mount remote shares, use SMBFS instead... installing whole Samba is a bit overkill in that situation.
  • »09.07.13 - 15:38
    frank
    I would like to share Files between my MosphOS Box and my OSX Computer use the SMB Protocol ...
  • »09.07.13 - 15:46
    frank
    How do i install SMBFS on MorphOS 3.2 ... ?
    ... where can I download it ?
    Can I use it to copy data in both directions ?
  • »10.07.13 - 06:29
    Posts: 12572 from 2003/5/22
    > How do i install SMBFS on MorphOS 3.2 ... ? ... where can I download it ?
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=6371&start=32
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=9&topic_id=7097&start=2
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=8585&start=3
    Yes.
  • »10.07.13 - 06:57
    Intuition
    Posts: 1116 from 2013/5/24
    http://www.amiga.org/forums/showpost.php?p=683287&postcount=2
    I recommend putting the smb statement in your s:network-startup with a 'wait 3' before it. You might need to experiment with the amount of waiting time to give the mossys:s/network-startup time to fully initialize the network connection.
    [ Edited by Intuition 10.07.2013 - 15:01 ]
  • »10.07.13 - 11:57
    frank
    Thank you to both, i will Test it ...
  • »10.07.13 - 12:16
    Tom01
    Posts: 187 from 2009/9/20
    You don't put a wait in front of it.
    After the line ";Start services", the network is up.
    Copy smbfs to C: then put something like this into network-startup:
    RUN > NIL: STACK 50000 SMBFS VOLUME=PC: CACHE=1024 Workgroup=WORKGROUP User=username Password=password Service=//computername/SharedDocs
    Certainly the Pc has to be up and running for this line to succeed.
    You can also put that line into a text file, save an icon for it, set the S flag and start it when needed by a mouse click.
  • »17.07.13 - 20:33
    Intuition
    Perhaps on your machines you don't have to put a wait but on mine one certainly has to.
  • »17.07.13 - 21:16
