Fab - I think Youtube broke itself again :-(
    redrumloa
    Posts: 1424 from 2003/4/13
    Can you look at the script please :-(
  • »20.06.13 - 00:18
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Youtube managed to double-annoy me:
    First they enforce their HTML5 player and replace the builtin player i use to replace Flash... :)
    And secondly, they sometimes feed a blob mediasource instead of a direct url to the media when using their own HTML5 player, which is not supported.
    As a workaround, you can still click the rightmost small "18" (or whatever) link below the video to replace (AGAIN) the player they spawn and it will work using the builtin HTML5 player (these links are added by the youtube.js script).
    For the blob thing when using their own HTML5 player, i fear it requires a new OWB version (assuming it can be dealt with).
    [ Edited by Fab 20.06.2013 - 11:06 ]
  • »20.06.13 - 08:04
    Ingo
    Posts: 103 from 2004/3/19
    Spoofing as iPad still works. But that's not really nice.
  • »20.06.13 - 14:56
    Posts: 12543 from 2003/5/22
    Agreed. The thing I miss most in Youtube's mobile mode is a working (as in overlay-enabling) fullscreen button. Fab said he might try to do something about that.
  • »20.06.13 - 15:07
    Intuition
    Posts: 1116 from 2013/5/24
    YouTube works here, just checked three or four videos.
    [ Edited by Intuition 20.06.2013 - 18:33 ]
  • »20.06.13 - 15:21
    cip060
    Posts: 151 from 2010/7/30
    Fab how do we see the video with joutube?
    Are you working on the script to restore the vision of video from joutube?
  • »21.06.13 - 17:41
  • Fab
    Fab
    It still works by clicking the "18" link below, for instance.
    I already explained earlier the various ways youtube decided to break, and none of them are trivial to "fix".
  • »21.06.13 - 21:22
    Ingo
    This intermediate solution often ends up with no sound for me.
  • »22.06.13 - 04:39
  • Fab
    Fab
    Since there's a point where two players are running at the same time, and you apparently didn't set "Unit 0 : blah" as musical unit.
    Let me remind you that OWB uses AHI exclusive music unit, so you have to redirect it to unit 0 to share sound between several instances. Once done, you'll have sound, always.
  • »22.06.13 - 05:57
    Ingo
    Oops, indeed! Somehow i missed that :-)
    Thanks Fab.
  • »22.06.13 - 06:44
    Travis_H
    Posts: 165 from 2009/12/17
    Google related...
    The new version of Maps really doesn't work well with OWB 1.20. It eventually fails.
    TJH
  • »22.06.13 - 13:13
    Intuition
    Seriosuly, Youtube works fine here.
    Shall I post a screenshot of it playing a video to show what i'm "doing wrong". ;)
  • »22.06.13 - 13:42
  • Fab
    Fab
    I just updated the youtube.js userscript. It deals with the various ways youtube decided to break. That said, i wouldn't be surprised if it would still break soonish. They do really WEIRD stuff.
  • »22.06.13 - 18:33
    cip060
    Fab thanks for the great work you do for the community '
    We hope that the idiots of youtube stop the change every time what I already 'works and finally pass to html 5
  • »22.06.13 - 18:55
    stephen_robinson
    Posts: 746 from 2007/4/22
    Installed the update, all working for me again, that little trick with 18 also worked.
    So all good, until they break it again.  :-x
  • »22.06.13 - 19:13
    bash64
    Posts: 974 from 2010/10/28
    how do i define a default muic unit as asked to do above?
  • »22.06.13 - 23:26
    redrumloa
    bash64,
    Top menu->Settings->System->Audio
    Make sure Music Unit is selected from the drop down and select Unit 0: HiFi 16bit Stero+++
    Click save
  • »23.06.13 - 02:02
    bash64
    I am using a Powerbook with mos 3.2. There is no drop down to select HiFi like I used to be able to when I ran os 3.1.
    There is a settings->system->Sound
    but no Audio icon in the control panel.
    There is no drop down in the sound settings beyond the normal default menu items when right clicking.
  • »25.06.13 - 23:52
    Ingo,
    Works fine for me.
  • »26.06.13 - 00:16
    boot_wb
    Posts: 874 from 2007/4/9
    Hi Bash64,
    'Sound' is in the top row of preferences (under the User Interface subheading) and allows you to set system sounds, etc
    'Audio' is in the bottom row (under the 'Hardware' subheading) and allows you to configure the audio hardware.
    If it isn't there, something is very wrong. :-)
    Regards
    Rich
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »26.06.13 - 06:28
    bash64
    I am officially blinder than a bat.
    Audio was there all along.
    I set it to Unit 0 Hifi 16bit stereo ++
    Thanks
     :-D
  • »26.06.13 - 07:52
    bash64
    spoofing as iPad causes giant chunky video.
    makes me unhappy.
  • »06.07.13 - 09:40
    ausPPC
    Posts: 543 from 2007/8/6
    Fab,
    Would that have anything to do with an ongoing effort to break the downloader sites and apps?
  • »06.07.13 - 23:28
