                Posts: 568 from 2003/2/24
				Hi everybody,
Does anyone has a tool installed in Yam to read HTML-pages correctly?
I've tried HTMLRead.
Installed it according the doc.
But I get an error when it opens IBrowse to display the HTML-message, the error is: AREXX port IBROWSE not found (or so).
I've installed AREXX correctly. Using AREXX-scripts from DirOpus without problems.
Next question is about MIME.
Is it possible to send mail to pc-owners with bold, coloured text and they can see it?
And my last question
What do you suggest I should install in/for YAM to make life more easier than it already is?
Thanks,
Spidey
