Small digital clock for MorphOS 3.2 panels
    Posts: 2539 from 2003/2/24
    The orginal idea of me redoing the Ambient panels had been the possibility to add new external classes just like those for the screenbar. For developing and testing I had created this not-so-good-looking clock:
    http://www.steamdraw.homepage.t-online.de/DigiClock.lha
    For installation just follow included readme.
    I might also note that this is just an "as is" piece of SW that might very well stop working with future MorphOS releases since the APIs aren't yet set in stone.
  • »30.05.13 - 09:56
    Develin
    Posts: 100 from 2003/4/19
    Nice, hope we'll see more modules soon =)
    I've noticed when I use Alpha = 0 on the panel the clock is not visible, just wanted to inform you about that =)
    Oh, I noticed that I could change its own alpha-value aswell.. now It's working!
    [ Edited by Develin 30.05.2013 - 14:16 ]
  • »30.05.13 - 10:10
    Guess I need to change the default color to solid black or white ......
  • »30.05.13 - 10:21
    Krashan
    Posts: 1107 from 2003/6/11
    Looks very promising. I have some ideas for panel classes... There is not enough space on the screenbar for some things, but panel can provide just enough :-).
  • »30.05.13 - 14:46
    eastone
    Posts: 47 from 2007/8/4
    I like it :)
  • »30.05.13 - 17:46
    amiga4001
    Posts: 454 from 2006/11/16
    Good idea!
  • »31.05.13 - 03:30
    Posts: 1076 from 2004/9/23
    Here two lame panels I found so far:
    http://www.geit.de/tmp/Elephant.pobj
    http://www.geit.de/tmp/MouseEye.pobj
  • »31.05.13 - 10:28
    igracki
    Posts: 469 from 2003/2/24
    A weather pobj would be cool!
  • »31.05.13 - 15:24
    Develin
    First attempt of ZoomIT inside of a panel object...
    It's not ready yet, just so you know =)
    http://www.onyxsoft.se/stefan/beta/ZoomIT.pobj
    [ Edited by Develin 04.06.2013 - 10:58 ]
  • »04.06.13 - 06:52
  • rNx
    rNx
    Posts: 35 from 2010/10/26
    Anyone up for a task to create simple text button panel :-) ? I mean app launcher with text buttons instead of icon.
    [ Edited by rNx 04.06.2013 - 15:08 ]
  • »04.06.13 - 10:06
    boot_wb
    Posts: 874 from 2007/4/9
    A MagicBeacon panel item would be cool. =)
    (PS Is your geit-AT-gmx.de address working - sent you an e-mail about Grunch a few weeks back)
    [ Edited by boot_wb 05.06.2013 - 00:24 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »04.06.13 - 12:57
    boot_wb
    A scriptable button (eg taking drag'n'drop filename as passed arguement) would be nice too!
    Are there any example sources available yet? Haven't had a proper look through the new release yet (even the release notes took long enough!)
  • »04.06.13 - 13:38
