Posts: 298 from 2008/10/27
Hello guys, just upgraded to 3.2 and downloaded the latest sdk, but when i go to the sdk installer, it showed a window the first time(it wont happent on subsequent runs), showing a text that appears like garbled characters, telling that the volume ...... cannot be found. Is anything required previous to the installation of this version?. With the older sdk never encountered any similar.
Thanks!!!!
P.D: I forgot to say that i upgraded from MorphOS 3.0 to 3.2 and the install went ok without problems. Only a text was given when specified the destiny of the installation, telling that there were no 3.2 system(unable to locate, or similar warning), but that's ok, as i was then on a 3.0. Update went ok and without weird incidents.
[ Editado por _ThEcRoW 03.06.2013 - 15:14 ]Mac Mini G4 1,4ghz 1gb ram & MorphOS 3.11
