WIPEOUT 2097
    Sphinx_Ra
    Posts: 276 from 2003/3/14
    Hello,
    I like the game Wipeout 2097,
    only it plays not well on my Peg2,
    It dramatically slows down, as if it freezes the system for short while's , anybody
    had this experience to ?!?!
    I saw ppl on BAS2003 show on Genesi stand playing
    this game very smoothy, is there a patch ???
    Somebody told me that it has to do with chip memory acces ?!?!?
    Thx
    Thx
  • »18.01.04 - 13:52
    warface
    Posts: 653 from 2003/2/24
    The original game engine is buggy, and generates hits, which slows downs the game itself. The bug remains hidden on the first map of the game.
  • »18.01.04 - 16:40
    Sphinx_Ra
    @warface
    Oke, thanx for the info, but...
    THERE is a good engine then or a patch ?!?!
    Because i really saw it on the show :-?
  • »18.01.04 - 16:45
    Posts: 261 from 2003/3/13
    I also seen all levels run on a pegasos at BAS, how did they do that ...
    beats me..
  • »19.01.04 - 06:03
    Sphinx_Ra
    @Felix
    Yep, i'm not the only one then....
  • »20.01.04 - 14:47
    serge
    Posts: 725 from 2003/2/20
    Cool, but where is this engine ? I want it, we all want it.
  • »20.01.04 - 15:24
    Posts: 2727 from 2003/2/24
    Sphinx_Ra wrote:
    Hello,
    Thx
    Is there HW 3D support or is the game you are running using SW rendering only? I have not tried this game on MorphOS myself, so I don't know, but AFAIR Wipeout 2097 was on display at some show using hardware 3D acceleration (actually Radeon if I remember correctly). That should be pretty smooth. Perhaps that's what you saw?
  • »20.01.04 - 15:55
    Sphinx_Ra
    @takemehomegrandfather :-)
    Well.. In the GUI there is a button/option for HW3D but it is dark (not clickelble) so i think
    that it use SW...or not that i don't no :-(
    I have VooDoo3 2000 (and use it for the game)
    so then it use HW right ???
    Or are they two sepperant things ???
    Beats me :-)
  • »20.01.04 - 17:57
    bigfoot
    Posts: 510 from 2003/4/11
    See here for a patch for Wipeout 2097.
    Don't forget to read the readme :)
  • »20.01.04 - 20:19
    guruman
    Posts: 461 from 2003/7/21
    @ Sphinx_Ra
    AFAIK WipeOut 2097 works in 3D accelerated mode only. It shouldn't have a SW renderer. In fact I guess you can play it only thanks to the fact you own a VooDoo card. But I remember I red somewhere you shouldn't use resolutions higher than 640*480: in your case the gfx card is the bottleneck.
    But I might be wrong... :-P
    Kind regards,
    Andrea
  • »20.01.04 - 20:41
    Estrayk
    Posts: 142 from 2003/12/30
    OFFTOPIC but when you said:
    "seen at BAS2003" you mean in a video downloaded from any site from Internet or you mean in the real place.?
    If can be downloaded that video from any site, please tell me the URL.
    thx
    Config: PegasosII G4/1000, 256MB DDR400, VooDoo 3000 AGP
  • »20.01.04 - 22:11
    Estrayk
    By the way, seems a "pacthed" loader has been released at: http://80.197.46.38/~bigfoot/files/
  • »20.01.04 - 22:17
    I knew it, i knew it, i knew it .. :)
    TNX
  • »21.01.04 - 06:12
    Sphinx_Ra
    @Estrayk
    The REAL place offcoursse  :-)
    But i know which video you mean,
    I think it was:
    http://lilith.sixgirls.org/ryu/  ;-)
  • »21.01.04 - 12:39
    Sphinx_Ra
    @guruman
    Thanks for the info :-)
    I will try that to ;-)
    @bigfoot
    THANX !!!! :-D
    Works great :-)
  • »21.01.04 - 12:41
    Posts: 33 from 2003/6/17
    Hi
    I tried that patch out. It runs with some little interruptions. It is very playable now, even with 1024*768. With 800*600 it is too fast :-D
    I played Wipeout on PegI with a Voodoo3 3500 here.
    PegII, 512 MB Ram, Radeon 8500, NEC USB-Card
  • »21.01.04 - 18:46
    Sphinx_Ra
    @grooves
    I have now LITTLE interruptions to so,
    but it still is annoying when you are "IN TO THE GAME" :-)
    And "Venom" Class is not playble, the pegasos is to fast,even with SM 1024x768 :-) even the sound when you die or to late for checkpoint goes faaaast :lol:
    To bad, i have to go to my OLD ugly PSX1 for playing that cool game :-)
    I think it is because i'm on a PegII and G4 :-D
  • »21.01.04 - 19:41
    Jupp3
    Posts: 1193 from 2003/2/24
    iirc, you can set various graphic details (such as drawing distance) with function keys... Set them to full, maybe that will slow the game down, just a (necessary) bit :-)
  • »27.01.04 - 16:38
    Sphinx_Ra
    @Jupp3
    I already tryd that, makes no diffrents,
    It's just goes to faaaaaaaast :-)
  • »27.01.04 - 17:17
    Miky060
    Posts: 694 from 2003/2/24
    Just unselect "unlimited" in "Speed limit" and use 60fps.
    Has someone been able to use Joypad with Wipeout? It seems to not work here (USB one)..
  • »27.01.04 - 19:14
    Sphinx_Ra
    @Miky060
    That helps not to, maybe the Speed Limit must be lower ???
    My USB-PSX Adapter is on his way at CompCity, i hope
    to get it this week :-)
    But if it's not working at your place i'm not happy, WIPEOUT was the reason that i ordered the Adapter .... grrr
    I will let you know if it works or not when i have have the Adapter :-)
  • »27.01.04 - 19:20
