where to autostart setclockntp
    TheMagicM
    Posts: 1220 from 2003/6/17
    I've put it in startup-sequence and user-startup, but it never updates my system clock. My batt is probably bad on the G4 I'm assuming. Regardless..what am I doing wrong?
  • »07.05.13 - 01:02
    Krashan
    Posts: 1107 from 2003/6/11
    Note that TCP/IP stack and your network interface must be up before running it. Personally I run it from the last line of S:network-startup.
  • »07.05.13 - 04:22
    Posts: 1076 from 2004/9/23
    As Krashan wrote. Create a file s:network-startup with the following contents:
    execute MOSSYS:s/network-startup
    Run DETACH MOSSYS:C/SetClockNTP
    Do not edit MOSSYS:s/network-startup. The newly created file is the perfect place to start all tools that require network like SMBFS or ftp/http servers, weather tools, ...
    Geit
  • »07.05.13 - 07:53
    bash64
    Posts: 974 from 2010/10/28
    Been looking for this answer for a long time.
    Always had trouble with "wetter" starting up to soon.
     :-D
  • »07.05.13 - 07:58
    TheMagicM
    excellent. Thanks!
  • »07.05.13 - 17:15
