Pagestream 4 No Text
    pan1k
    Posts: 147 from 2009/1/20
    I got it to run now, but no text. I tried:
    16bit screen depts
    Setting the fonts
    Checked the assigns about 3x
    Anything else I can try from your experiances? I saw the articles in the forums already, tried everything suggested..
    MacMini with 32MB VRAM and Morph 3.6
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »06.09.14 - 15:43
    amiga4001
    Posts: 451 from 2006/11/16
    Has something to do with the colors I think..Try other background color
  • »07.09.14 - 08:19
    tolkien
    Posts: 550 from 2013/5/29
    Ehem...any news about a new morphos version of pagestream?
  • »07.09.14 - 12:31
    tolkien
  • »07.09.14 - 12:36
    pan1k
    I tried changing the pasteboard color. No dice. At this point I hope I can get a refund. MorphOS version were there but not available for dowload.
  • »07.09.14 - 14:16
    Tomo
    Posts: 92 from 2003/7/29
    I have Pagestream 4 running (for many years) on my PegII, with Screen 1920 * 1080 16bit en 61.05 hz without problems (Radeon 9200). No luck for the Pagestream5 upgrade (still waiting...)
    regards Tom
  • »07.09.14 - 15:34
    NewSense
    Posts: 1535 from 2012/11/9
    Try renaming the Pagestream.prefs file with the ending ORIG, or something similar, and using the file as a starting point copy the text file and rename it to Pagestream.prefs again. I seem to remember it was an issue with the assign of the FONTS: directory, so you can edit the prefs file with a standard text editor, and where in the prefs it indicates FONTS: as the correct directory I changed mine to Pagestream4:Fonts (make sure that Pagestream4: is assigned in your user-startup.
    If that doesn't work then just delete the Pagestream.prefs file (as you will have the Pagestream.prefsORIG copy of the prefs file to fallback to - if necessary) and close the program, if you have it open. Which should let Pagestream re-create a new Pagestream.prefs file when it starts up.
    I seem to remember that fixed the issue I had with getting the fonts to display correctly, along with the 16 bit screenmode, but you already seem to be aware of that issue.
    I had similar troubles with Pagestream, and it was a real pain to get it working well, but once fixed it works fine on my Mac Mini MOS system, and I hope it will for you as well.
    I believe Deron Kazmaier (Pagestream author) is working on a MorphOS port of Pagestream, but don't hold your breath, as his work output for Pagestream of recent, and his response to questions has been sadly overly delayed, or met with no reply, but I believe he has been in contact with the MOS Development team recently and confirmed he is working on the MOS port of Pagestream.
    Anyway, good luck with getting Pagestream working correctly, and please let us all know how you get on.
  • »07.09.14 - 15:52
    Posts: 2165 from 2003/2/24
    I had issue that default font didn't give anything, but when I changed to other fonts from the menus, they did work.
    Actually I just checked it and it has some default font which I don't have (or I have some assign or other problem). If I open font selection window and click "Show Sample" it doesn't show anything on it with default font. If I select some other font from the list, it shows sample just fine.... buut then for some reason some of them actually work when trying to write into text box, but some others don't... hmm..
    [ Edited by jPV 07.09.2014 - 18:55 ]
  • »07.09.14 - 16:49
    NewSense
    I know, it is a really weird problem, and one that I am not sure, even now, I fully understand how I fixed it, but it is working for me now, so I am not going to mess up my setup again to find out what casued and then fixed it exactly, but it seemed to me to be a font issue - possibly caused by Pagestream misreading its own Pagestrem.prefs file.
  • »07.09.14 - 19:50
    Tomo
    [If it's Font's question, then go to Pagestream/Softlogic/Csets and place all the files that don't start with 'ISO....txt' in a separate folder and give it an other name ('Disabled'?) That was for me the trick to start Pagestream 4.
    Regards Tom
  • »08.09.14 - 05:15
    NewSense
    Yes, that was mentioned when I had problems with setting up Pagestream, the fonts not displaying on screen properly, but I don't seem to remember that fixing it fully for me, but that is also worth doing as well - renaming the CSets directory to, as you say, 'Disabled', and see if that also helps to get Pagestream to work correctly. Once it is setup it works fine it seems.
  • »08.09.14 - 12:01
    pan1k
    I tried the prefs file. Even did the font prefs file. As soon as I changed the fonts prefs, no fonts are displayed. I know my assigns are setup correctly, it's a fresh install.
    I tried:
    Pagestream:Fonts
    Pagestream4:Fonts
    and then Fonts/ as it was when it was installed. No dice.
  • »10.09.14 - 01:45
    But can you write at leat with some of the fonts, if you try to select them from top to down until you find some working one for example?
  • »10.09.14 - 03:13
    NewSense
    When I had this issue, then I could not use ANY font, and the font list within Pagestream GUI goes empty, even though the fonts are in their respective drawers/folders/directories, and they are correcfly assigned. It really is a weird problem, but one of the suggestions that have been suggested here, or a combination of them fixed the issue I was having with Pagestream, and my installation works virtually as it did on my classic Amiga system, which is great.
  • »10.09.14 - 19:21
    pan1k
    Newsense,
    Can you open your font prefs and tell me how it looks? Do you have the default drawer specified? Are the entries like Pagestream:Fonts/etc ?
  • »11.09.14 - 00:03
    NewSense
    The Font entry in my Pagestream.prefs file is listed as:
    SETFONTPATH Pagestream:Fonts
    [ Edited by NewSense 11.09.2014 - 00:20 ]
  • »11.09.14 - 00:19
    pan1k
    Tried that NewSense. I did a fresh install just now also. What screenmode do you have in your prefs file? Now my fonts show up in the list, but no matter what font I choose, it always goes back to the default Triumvirate or whatever which is in the path. No luck.
  • »11.09.14 - 01:36
    NewSense
    The screenmode line in my Pagestream.prefs file is:-
    SCREEN Public 1280 1024 16 "Radeon9200: 16Bit 1280 x 1024" "Bitstream Vera Sans.font" 15
    Hope this helps - you did change the CSets name to DISABLED or something else than CSets as well I hope?
  • »11.09.14 - 19:57
    pan1k
    I moved all the files in the CSets folder to disabled. I shouldn't need any of them as Amiga, Mac and Windows Char sets are built in. I'll try the Public Screen...
    Chris
  • »11.09.14 - 22:57
    pan1k
    I just did a fresh install on my G4 MDD. Same result. Maybe it's some kind of ASSIGN issue, but i'm following what you guys have done, no luck whatsoever.
    I even threw the fonts for Pagestream in the Softlogik folder and pointed the prefs there, no luck. Not sure what to do. I hate to ask Derek for a refund but.. I think I have spent at least 12 hours trying to "make" this work.
    Anything else I can try?
    PS my MDD G4 is running Morph 3.4 so I dont think its the version of Morph...
    [ Edited by pan1k 11.09.2014 - 17:05 ]
  • »12.09.14 - 01:03
    pan1k
    [1] [PageStream4] [ChangeDir] [MorphOS:Applications/PageStream] [] []
    [2] [PageStream4] [Open] [con:10/10/320/80/PageStream4/auto/close/wait] [Write] [OK]
    [3] [PageStream4] [Open] [NIL:] [Read] [OK]
    [4] [PageStream4] [Open] [NIL:] [Write] [OK]
    [5] [PageStream4] [Open] [*] [Read] [OK]
    [6] [ramlib] [Load] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [] [Fail]
    [7] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [8] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [9] [ramlib] [Load] [SOFTLOGIK:libs/softlogik_os_fpu.library] [] [Fail]
    [10] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library] [Read] [Fail]
    [11] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library] [Read] [Fail]
    [12] [ramlib] [Load] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [] [Fail]
    [13] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [14] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [15] [ramlib] [Load] [libs/softlogik_os_fpu.library.elf] [] [Fail]
    [16] [ramlib] [Open] [libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [17] [ramlib] [Open] [libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [18] [ramlib] [Load] [SOFTLOGIK:libs/softlogik_os_fpu.library] [] [Fail]
    [19] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library] [Read] [Fail]
    [20] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library] [Read] [Fail]
    [21] [ramlib] [Load] [libs/softlogik_os_fpu.library] [] [Fail]
    [22] [ramlib] [Open] [libs/softlogik_os_fpu.library] [Read] [Fail]
    [23] [ramlib] [Open] [libs/softlogik_os_fpu.library] [Read] [Fail]
    [24] [PageStream4] [ChangeDir] [MorphOS:Applications/PageStream] [] []
    [25] [PageStream4] [Open] [PageStream4.info] [Read] [OK]
    [26] [PageStream4] [ToolType] [PORTNAME] [] [Fail]
    [27] [PageStream4] [ToolType] [STARTUP] [] [Fail]
    [28] [PageStream4] [ToolType] [PUBSCREEN] [] [Fail]
    [29] [PageStream4] [ToolType] [SCREEN] [] [Fail]
    [30] [PageStream4] [ToolType] [DEBUG] [] [Fail]
    [31] [PageStream4] [ToolType] [SETTINGS] [] [Fail]
    [32] [PageStream4] [ToolType] [RSRCFILE] [] [Fail]
    [33] [PageStream4] [ToolType] [DISPLAYDPI] [] [Fail]
    [34] [PageStream4] [ToolType] [REFRESH] [] [Fail]
    [35] [PageStream4] [ToolType] [OPENSCREENBEHIND] [] [Fail]
    [36] [PageStream4] [ToolType] [CENTERONDCLIP] [] [Fail]
    [37] [PageStream4] [ToolType] [SHOWMEMORY] [] [Fail]
    [38] [PageStream4] [ToolType] [SHOWDATE] [] [Fail]
    [39] [PageStream4] [ToolType] [SHOWTIME] [] [Fail]
    [40] [PageStream4] [ToolType] [FILEFILTER] [] [Fail]
    [41] [PageStream4] [ToolType] [USEASLPATHREQ] [] [Fail]
    [42] [PageStream4] [ToolType] [COLOR0] [] [Fail]
    [43] [PageStream4] [ToolType] [COLOR1] [] [Fail]
    [44] [PageStream4] [ToolType] [COLOR2] [] [Fail]
    [45] [PageStream4] [ToolType] [COLOR3] [] [Fail]
    [46] [PageStream4] [ToolType] [COLOR4] [] [Fail]
    [47] [PageStream4] [ToolType] [COLOR5] [] [Fail]
    [48] [PageStream4] [ToolType] [COPYFTXT] [] [Fail]
    [49] [PageStream4] [ToolType] [COPYCTXT] [] [Fail]
    [50] [PageStream4] [ToolType] [COPYDR2D] [] [Fail]
    [51] [PageStream4] [ToolType] [COPYILUS] [] [Fail]
    [52] [PageStream4] [ToolType] [DEBUGMH] [] [Fail]
    [53] [PageStream4] [ToolType] [SETCURSORFLASH] [] [Fail]
    [54] [PageStream4] [ToolType] [SHOWTOOLBAR] [] [Fail]
    [55] [PageStream4] [ToolType] [SHOWSTATUSBAR] [] [Fail]
    [56] [PageStream4] [ToolType] [SETDEFAULTFONTSPEC] [] [Fail]
    [57] [PageStream4] [ToolType] [DEBUG] [] [Fail]
    [58] [PageStream4] [ToolType] [NOAUTOHELP] [] [Fail]
    [59] [PageStream4] [ToolType] [SETUNDOLEVELS] [] [Fail]
    [60] [PageStream4] [ToolType] [SETBACKUP] [] [Fail]
    [61] [PageStream4] [ToolType] [SETREVISIONTRACKING] [] [Fail]
    [62] [PageStream4] [ToolType] [SETCURSORFLASH] [] [Fail]
    [63] [PageStream4] [ToolType] [USE3DINTERFACE] [] [Fail]
    [64] [PageStream4] [ToolType] [SHOWCTRLKBE] [] [Fail]
    [65] [PageStream4] [ToolType] [SETSCRATCHPATH] [] [Fail]
    [66] [PageStream4] [ToolType] [USESCRATCH] [] [Fail]
    [67] [PageStream4] [ToolType] [SETVIEWDEFAULTS] [] [Fail]
    [68] [PageStream4] [ToolType] [SETSMART] [] [Fail]
    [69] [PageStream4] [ToolType] [SETFONT] [] [Fail]
    [70] [PageStream4] [ToolType] [SETTYPESIZE] [] [Fail]
    [71] [PageStream4] [ToolType] [SETTYPEWIDTH] [] [Fail]
    [72] [PageStream4] [ToolType] [SETLANGUAGE] [] [Fail]
    [73] [PageStream4] [ToolType] [SETTYPEANGLE] [] [Fail]
    [74] [PageStream4] [ToolType] [SETBASELINE] [] [Fail]
    [75] [PageStream4] [ToolType] [SETNORMAL] [] [Fail]
    [76] [PageStream4] [ToolType] [SETBOLD] [] [Fail]
    [77] [PageStream4] [ToolType] [SETITALIC] [] [Fail]
    [78] [PageStream4] [ToolType] [SETSHADOW] [] [Fail]
    [79] [PageStream4] [ToolType] [SETOUTLINE] [] [Fail]
    [80] [PageStream4] [ToolType] [SETUNDERLINE] [] [Fail]
    [81] [PageStream4] [ToolType] [SETREVERSE] [] [Fail]
    [82] [PageStream4] [ToolType] [SETSMALLCAPS] [] [Fail]
    [83] [PageStream4] [ToolType] [SETSCRIPT] [] [Fail]
    [84] [PageStream4] [ToolType] [SETSUPERSCRIPT] [] [Fail]
    [85] [PageStream4] [ToolType] [SETSUBSCRIPT] [] [Fail]
    [86] [PageStream4] [ToolType] [SETCASE] [] [Fail]
    [87] [PageStream4] [ToolType] [SETALIGNMENT] [] [Fail]
    [88] [PageStream4] [ToolType] [SETLASTLINEFLUSH] [] [Fail]
    [89] [PageStream4] [ToolType] [SETMINLINELENGTH] [] [Fail]
    [90] [PageStream4] [ToolType] [SETTRACKING] [] [Fail]
    [91] [PageStream4] [ToolType] [SETTRACKTABLE] [] [Fail]
    [92] [PageStream4] [ToolType] [SETTRACKRANGE] [] [Fail]
    [93] [PageStream4] [ToolType] [SETKERNING] [] [Fail]
    [94] [PageStream4] [ToolType] [SETOPTICAL] [] [Fail]
    [95] [PageStream4] [ToolType] [SETHANGING] [] [Fail]
    [96] [PageStream4] [ToolType] [SETHYPHENATION] [] [Fail]
    [97] [PageStream4] [ToolType] [SETHYPHENLANGUAGE] [] [Fail]
    [98] [PageStream4] [ToolType] [SETLIGATURE] [] [Fail]
    [99] [PageStream4] [ToolType] [SETFIRSTLINE] [] [Fail]
    [100] [PageStream4] [ToolType] [SETINDENT] [] [Fail]
    [101] [PageStream4] [ToolType] [SETLEADING] [] [Fail]
    [102] [PageStream4] [ToolType] [SETBASELINELEADING] [] [Fail]
    [103] [PageStream4] [ToolType] [SETPARAGRAPHLEADING] [] [Fail]
    [104] [PageStream4] [ToolType] [SETDROPCAP] [] [Fail]
    [105] [PageStream4] [ToolType] [SETBULLET] [] [Fail]
    [106] [PageStream4] [ToolType] [SETNUMBERED] [] [Fail]
    [107] [PageStream4] [ToolType] [SETRULEABOVE] [] [Fail]
    [108] [PageStream4] [ToolType] [SETRULEBELOW] [] [Fail]
    [109] [PageStream4] [ToolType] [SETTABRULER] [] [Fail]
    [110] [PageStream4] [ToolType] [SETDEFAULTTABSTOP] [] [Fail]
    [111] [PageStream4] [ToolType] [SETDIRECTION] [] [Fail]
    [112] [PageStream4] [ToolType] [SETPDFPATH] [] [Fail]
    [113] [PageStream4] [ToolType] [SETMAILMERGEPATH] [] [Fail]
    [114] [PageStream4] [ToolType] [SETPRINTPATH] [] [Fail]
    [115] [PageStream4] [ToolType] [SETLIVEUPDATE] [] [Fail]
    [116] [PageStream4] [ToolType] [SETDOUBLECLICK] [] [Fail]
    [117] [PageStream4] [ToolType] [SETNUDGEDEFAULTS] [] [Fail]
    [118] [PageStream4] [ToolType] [SETDUPLICATEDEFAULTS] [] [Fail]
    [119] [PageStream4] [ToolType] [SETMEASUREMENTS] [] [Fail]
    [120] [PageStream4] [ToolType] [FILEFILTER] [] [Fail]
    [121] [PageStream4] [ToolType] [SETPASTEINCENTER] [] [Fail]
    [122] [PageStream4] [ToolType] [SELECTONPASTE] [] [Fail]
    [123] [PageStream4] [ToolType] [SETAUTOCOLUMNS] [] [Fail]
    [124] [PageStream4] [ToolType] [SETDOCUMENTPATH] [] [Fail]
    [125] [PageStream4] [ToolType] [SETTEXTPATH] [] [Fail]
    [126] [PageStream4] [ToolType] [SETGRAPHICPATH] [] [Fail]
    [127] [PageStream4] [ToolType] [SETSCRIPTPATH] [] [Fail]
    [128] [PageStream4] [ToolType] [SETFONTPATH] [] [Fail]
    [129] [PageStream4] [ToolType] [SETTEXTEDITOR] [] [Fail]
    [130] [PageStream4] [ToolType] [SETBITMAPEDITOR] [] [Fail]
    [131] [PageStream4] [ToolType] [SETDRAWINGEDITOR] [] [Fail]
    [132] [PageStream4] [ToolType] [SETMAGNIFYINCREMENT] [] [Fail]
    [133] [PageStream4] [ToolType] [SETBOXDEFAULTS] [] [Fail]
    [134] [PageStream4] [ToolType] [SETCOLUMNDEFAULTS] [] [Fail]
    [135] [PageStream4] [ToolType] [SETGRIDDEFAULTS] [] [Fail]
    [136] [PageStream4] [ToolType] [SETARCDEFAULTS] [] [Fail]
    [137] [PageStream4] [ToolType] [SETPOLYGONDEFAULTS] [] [Fail]
    [138] [PageStream4] [ToolType] [MAINTOOLBOX] [] [Fail]
    [139] [PageStream4] [ToolType] [TOOLBAR] [] [Fail]
    [140] [PageStream4] [ToolType] [SETTOOLBAR] [] [Fail]
    [141] [PageStream4] [ToolType] [EDITPALETTE] [] [Fail]
    [142] [PageStream4] [ToolType] [COLORPALETTE] [] [Fail]
    [143] [PageStream4] [ToolType] [FONTPALETTE] [] [Fail]
    [144] [PageStream4] [ToolType] [STYLEPALETTE] [] [Fail]
    [145] [PageStream4] [ToolType] [LAYERPALETTE] [] [Fail]
    [146] [PageStream4] [ToolType] [SCRIPTPALETTE] [] [Fail]
    [147] [PageStream4] [ToolType] [PAGEPALETTE] [] [Fail]
    [148] [PageStream4] [ToolType] [DOCUMENTPALETTE] [] [Fail]
    [149] [PageStream4] [ToolType] [SETWINDOWDEFAULTS] [] [Fail]
    [150] [PageStream4] [ToolType] [SETMOVEDEFAULTS] [] [Fail]
    [151] [PageStream4] [ToolType] [RECENTFILES] [] [Fail]
    [152] [PageStream4] [ToolType] [USERNAME] [] [Fail]
    [153] [PageStream4] [ToolType] [USERCOMPANY] [] [Fail]
    [154] [PageStream4] [ToolType] [USERREGNUM] [] [Fail]
    [155] [PageStream4] [ToolType] [USERPASSWORD] [] [Fail]
    [156] [PageStream4] [ToolType] [SETDIMENSIONS] [] [Fail]
    [157] [PageStream4] [ToolType] [SETBLEED] [] [Fail]
    [158] [PageStream4] [ToolType] [SETMARGINGUIDES] [] [Fail]
    [159] [PageStream4] [ToolType] [SETCOLUMNGUIDES] [] [Fail]
    [160] [PageStream4] [ToolType] [SETGRID] [] [Fail]
    [161] [PageStream4] [ToolType] [SETFONTCACHE] [] [Fail]
    [162] [PageStream4] [ToolType] [UPDATEFONTPATHS] [] [Fail]
    [163] [PageStream4] [ToolType] [SETOUTPUT] [] [Fail]
    [164] [PageStream4] [ToolType] [SETOUTPUT1] [] [Fail]
    [165] [PageStream4] [ToolType] [SETOUTPUT2] [] [Fail]
    [166] [PageStream4] [ToolType] [SETOUTPUT3] [] [Fail]
    [167] [PageStream4] [ToolType] [SETOUTPUT4] [] [Fail]
    [168] [PageStream4] [ToolType] [SETOUTPUT5] [] [Fail]
    [169] [PageStream4] [ToolType] [SETOUTPUT6] [] [Fail]
    [170] [PageStream4] [ToolType] [SETOUTPUT7] [] [Fail]
    [171] [PageStream4] [ToolType] [SETOUTPUT8] [] [Fail]
    [172] [PageStream4] [ToolType] [SETOUTPUT9] [] [Fail]
    [173] [PageStream4] [ChangeDir] [MorphOS:Applications/PageStream] [] []
    [174] [PageStream4] [LockScreen] [Workbench] [] [OK]
    [175] [PageStream4] [LockScreen] [PageStream4] [] [Fail]
    [176] [« Skin Manager »] [ChangeDir] [MorphOS:MorphOS/Prefs/Skins/Mahalaxmi] [] []
    [177] [« Skin Manager »] [Open] [SkinConfig] [Read] [OK]
    [178] [« Skin Manager »] [ChangeDir] [MorphOS:MorphOS/Prefs/Skins/Mahalaxmi] [] []
    [179] [« Skin Manager »] [Open] [SysIClassSubMenu] [Read] [OK]
    [180] [« Skin Manager »] [ChangeDir] [SYS:] [] []
    [181] [« Skin Manager »] [ChangeDir] [MorphOS:MorphOS/Prefs/Skins/Mahalaxmi] [] []
    [182] [« Skin Manager »] [Open] [SysIClassMenuToggle] [Read] [OK]
    [183] [« Skin Manager »] [ChangeDir] [SYS:] [] []
    [184] [PageStream4] [Open] [PROGDIR:PageStream4] [Read] [OK]
    [185] [PageStream4] [Open] [PROGDIR:PageStream4] [Read] [OK]
    [186] [« Skin Manager »] [ChangeDir] [MorphOS:MorphOS/Prefs/Skins/Mahalaxmi] [] []
    [187] [« Skin Manager »] [ChangeDir] [SYS:] [] []
    [188] [« Skin Manager »] [ChangeDir] [MorphOS:MorphOS/Prefs/Skins/Mahalaxmi] [] []
    [189] [« Skin Manager »] [ChangeDir] [SYS:] [] []
    [190] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/TextFX.extension] [] [OK]
    [191] [PageStream4] [Open] [SOFTLOGIK:Engines/TextFX.extension] [Read] [OK]
    [192] [PageStream4] [Open] [SOFTLOGIK:Engines/TextFX.extension] [Read] [OK]
    [193] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Svenska.language] [] [OK]
    [194] [PageStream4] [Open] [SOFTLOGIK:Engines/Svenska.language] [Read] [OK]
    [195] [PageStream4] [Open] [SOFTLOGIK:Engines/Svenska.language] [Read] [OK]
    [196] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [197] [PageStream4] [Open] [NIL:] [Read] [OK]
    [198] [PageStream4] [Open] [NIL:] [Write] [OK]
    [199] [PageStream4] [Open] [*] [Read] [OK]
    [200] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Suomi.language] [] [OK]
    [201] [PageStream4] [Open] [SOFTLOGIK:Engines/Suomi.language] [Read] [OK]
    [202] [PageStream4] [Open] [SOFTLOGIK:Engines/Suomi.language] [Read] [OK]
    [203] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [204] [PageStream4] [Open] [NIL:] [Read] [OK]
    [205] [PageStream4] [Open] [NIL:] [Write] [OK]
    [206] [PageStream4] [Open] [*] [Read] [OK]
    [207] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Srpski.language] [] [OK]
    [208] [PageStream4] [Open] [SOFTLOGIK:Engines/Srpski.language] [Read] [OK]
    [209] [PageStream4] [Open] [SOFTLOGIK:Engines/Srpski.language] [Read] [OK]
    [210] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [211] [PageStream4] [Open] [NIL:] [Read] [OK]
    [212] [PageStream4] [Open] [NIL:] [Write] [OK]
    [213] [PageStream4] [Open] [*] [Read] [OK]
    [214] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Slovenian.language] [] [OK]
    [215] [PageStream4] [Open] [SOFTLOGIK:Engines/Slovenian.language] [Read] [OK]
    [216] [PageStream4] [Open] [SOFTLOGIK:Engines/Slovenian.language] [Read] [OK]
    [217] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [218] [PageStream4] [Open] [NIL:] [Read] [OK]
    [219] [PageStream4] [Open] [NIL:] [Write] [OK]
    [220] [PageStream4] [Open] [*] [Read] [OK]
    [221] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Polski.language] [] [OK]
    [222] [PageStream4] [Open] [SOFTLOGIK:Engines/Polski.language] [Read] [OK]
    [223] [PageStream4] [Open] [SOFTLOGIK:Engines/Polski.language] [Read] [OK]
    [224] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [225] [PageStream4] [Open] [NIL:] [Read] [OK]
    [226] [PageStream4] [Open] [NIL:] [Write] [OK]
    [227] [PageStream4] [Open] [*] [Read] [OK]
    [228] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/PageStream.codes] [] [OK]
    [229] [PageStream4] [Open] [SOFTLOGIK:Engines/PageStream.codes] [Read] [OK]
    [230] [PageStream4] [Open] [SOFTLOGIK:Engines/PageStream.codes] [Read] [OK]
    [231] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/PageMaker.codes] [] [OK]
    [232] [PageStream4] [Open] [SOFTLOGIK:Engines/PageMaker.codes] [Read] [OK]
    [233] [PageStream4] [Open] [SOFTLOGIK:Engines/PageMaker.codes] [Read] [OK]
    [234] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Norsk.language] [] [OK]
    [235] [PageStream4] [Open] [SOFTLOGIK:Engines/Norsk.language] [Read] [OK]
    [236] [PageStream4] [Open] [SOFTLOGIK:Engines/Norsk.language] [Read] [OK]
    [237] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [238] [PageStream4] [Open] [NIL:] [Read] [OK]
    [239] [PageStream4] [Open] [NIL:] [Write] [OK]
    [240] [PageStream4] [Open] [*] [Read] [OK]
    [241] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Nederlands.language] [] [OK]
    [242] [PageStream4] [Open] [SOFTLOGIK:Engines/Nederlands.language] [Read] [OK]
    [243] [PageStream4] [Open] [SOFTLOGIK:Engines/Nederlands.language] [Read] [OK]
    [244] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [245] [PageStream4] [Open] [NIL:] [Read] [OK]
    [246] [PageStream4] [Open] [NIL:] [Write] [OK]
    [247] [PageStream4] [Open] [*] [Read] [OK]
    [248] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Magyar.language] [] [OK]
    [249] [PageStream4] [Open] [SOFTLOGIK:Engines/Magyar.language] [Read] [OK]
    [250] [PageStream4] [Open] [SOFTLOGIK:Engines/Magyar.language] [Read] [OK]
    [251] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [252] [PageStream4] [Open] [NIL:] [Read] [OK]
    [253] [PageStream4] [Open] [NIL:] [Write] [OK]
    [254] [PageStream4] [Open] [*] [Read] [OK]
    [255] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Italiano.language] [] [OK]
    [256] [PageStream4] [Open] [SOFTLOGIK:Engines/Italiano.language] [Read] [OK]
    [257] [PageStream4] [Open] [SOFTLOGIK:Engines/Italiano.language] [Read] [OK]
    [258] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [259] [PageStream4] [Open] [NIL:] [Read] [OK]
    [260] [PageStream4] [Open] [NIL:] [Write] [OK]
    [261] [PageStream4] [Open] [*] [Read] [OK]
    [262] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Francais.language] [] [OK]
    [263] [PageStream4] [Open] [SOFTLOGIK:Engines/Francais.language] [Read] [OK]
    [264] [PageStream4] [Open] [SOFTLOGIK:Engines/Francais.language] [Read] [OK]
    [265] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [266] [PageStream4] [Open] [NIL:] [Read] [OK]
    [267] [PageStream4] [Open] [NIL:] [Write] [OK]
    [268] [PageStream4] [Open] [*] [Read] [OK]
    [269] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Espanol.language] [] [OK]
    [270] [PageStream4] [Open] [SOFTLOGIK:Engines/Espanol.language] [Read] [OK]
    [271] [PageStream4] [Open] [SOFTLOGIK:Engines/Espanol.language] [Read] [OK]
    [272] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [273] [PageStream4] [Open] [NIL:] [Read] [OK]
    [274] [PageStream4] [Open] [NIL:] [Write] [OK]
    [275] [PageStream4] [Open] [*] [Read] [OK]
    [276] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Deutsch.language] [] [OK]
    [277] [PageStream4] [Open] [SOFTLOGIK:Engines/Deutsch.language] [Read] [OK]
    [278] [PageStream4] [Open] [SOFTLOGIK:Engines/Deutsch.language] [Read] [OK]
    [279] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [280] [PageStream4] [Open] [NIL:] [Read] [OK]
    [281] [PageStream4] [Open] [NIL:] [Write] [OK]
    [282] [PageStream4] [Open] [*] [Read] [OK]
    [283] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Dansk.language] [] [OK]
    [284] [PageStream4] [Open] [SOFTLOGIK:Engines/Dansk.language] [Read] [OK]
    [285] [PageStream4] [Open] [SOFTLOGIK:Engines/Dansk.language] [Read] [OK]
    [286] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [287] [PageStream4] [Open] [NIL:] [Read] [OK]
    [288] [PageStream4] [Open] [NIL:] [Write] [OK]
    [289] [PageStream4] [Open] [*] [Read] [OK]
    [290] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/British.language] [] [OK]
    [291] [PageStream4] [Open] [SOFTLOGIK:Engines/British.language] [Read] [OK]
    [292] [PageStream4] [Open] [SOFTLOGIK:Engines/British.language] [Read] [OK]
    [293] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [294] [PageStream4] [Open] [NIL:] [Read] [OK]
    [295] [PageStream4] [Open] [NIL:] [Write] [OK]
    [296] [PageStream4] [Open] [*] [Read] [OK]
    [297] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Borders.extension] [] [OK]
    [298] [PageStream4] [Open] [SOFTLOGIK:Engines/Borders.extension] [Read] [OK]
    [299] [PageStream4] [Open] [SOFTLOGIK:Engines/Borders.extension] [Read] [OK]
    [300] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/American.language] [] [OK]
    [301] [PageStream4] [Open] [SOFTLOGIK:Engines/American.language] [Read] [OK]
    [302] [PageStream4] [Open] [SOFTLOGIK:Engines/American.language] [Read] [OK]
    [303] [PageStream4] [Open] [PROGDIR:PageStream4.fontprefs] [Read] [OK]
    [304] [PageStream4] [Open] [softlogik:libs/FontSubstitutionData] [Read] [OK]
    [305] [PageStream4] [Open] [softlogik:libs/KerningData] [Read] [Fail]
    [306] [PageStream4] [Open] [softlogik:libs/TrackingData] [Read] [Fail]
    [307] [PageStream4] [Open] [softlogik:libs/FontReencodeData] [Read] [Fail]
    [308] [PageStream4] [NewLoad] [SOFTLOGIK:Printers/Preference.printer] [] [OK]
    [309] [PageStream4] [Open] [SOFTLOGIK:Printers/Preference.printer] [Read] [OK]
    [310] [PageStream4] [Open] [SOFTLOGIK:Printers/Preference.printer] [Read] [OK]
    [311] [PageStream4] [Open] [SOFTLOGIK:printers/Preference.printer] [Read] [OK]
    [312] [PageStream4] [Open] [SOFTLOGIK:printers/Preference.printer] [Read] [OK]
    [313] [PageStream4] [NewLoad] [SOFTLOGIK:Printers/PostScript.printer] [] [OK]
    [314] [PageStream4] [Open] [SOFTLOGIK:Printers/PostScript.printer] [Read] [OK]
    [315] [PageStream4] [Open] [SOFTLOGIK:Printers/PostScript.printer] [Read] [OK]
    [316] [PageStream4] [NewLoad] [SOFTLOGIK:Printers/IFFILBM.printer] [] [OK]
    [317] [PageStream4] [Open] [SOFTLOGIK:Printers/IFFILBM.printer] [Read] [OK]
    [318] [PageStream4] [Open] [SOFTLOGIK:Printers/IFFILBM.printer] [Read] [OK]
    [319] [ramlib] [Load] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [] [Fail]
    [320] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [321] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [322] [ramlib] [Load] [SOFTLOGIK:libs/softlogik_os_fpu.library] [] [Fail]
    [323] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library] [Read] [Fail]
    [324] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library] [Read] [Fail]
    [325] [ramlib] [Load] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [] [Fail]
    [326] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [327] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [328] [ramlib] [Load] [libs/softlogik_os_fpu.library.elf] [] [Fail]
    [329] [ramlib] [Open] [libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [330] [ramlib] [Open] [libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [331] [ramlib] [Load] [SOFTLOGIK:libs/softlogik_os_fpu.library] [] [Fail]
    [332] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library] [Read] [Fail]
    [333] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library] [Read] [Fail]
    [334] [ramlib] [Load] [libs/softlogik_os_fpu.library] [] [Fail]
    [335] [ramlib] [Open] [libs/softlogik_os_fpu.library] [Read] [Fail]
    [336] [ramlib] [Open] [libs/softlogik_os_fpu.library] [Read] [Fail]
    [337] [PageStream4] [Open] [SOFTLOGIK:printers/IFFILBM.printer] [Read] [OK]
    [338] [PageStream4] [Open] [SOFTLOGIK:printers/IFFILBM.printer] [Read] [OK]
    [339] [PageStream4] [Open] [SOFTLOGIK:printers/XPD/IFFILBM] [Read] [OK]
    [340] [PageStream4] [NewLoad] [SOFTLOGIK:Printers/Hewlett-Packard.printer] [] [OK]
    [341] [PageStream4] [Open] [SOFTLOGIK:Printers/Hewlett-Packard.printer] [Read] [OK]
    [342] [PageStream4] [Open] [SOFTLOGIK:Printers/Hewlett-Packard.printer] [Read] [OK]
    [343] [ramlib] [Load] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [] [Fail]
    [344] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [345] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [346] [ramlib] [Load] [SOFTLOGIK:libs/softlogik_os_fpu.library] [] [Fail]
    [347] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library] [Read] [Fail]
    [348] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library] [Read] [Fail]
    [349] [ramlib] [Load] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [] [Fail]
    [350] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [351] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [352] [ramlib] [Load] [libs/softlogik_os_fpu.library.elf] [] [Fail]
    [353] [ramlib] [Open] [libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [354] [ramlib] [Open] [libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [355] [ramlib] [Load] [SOFTLOGIK:libs/softlogik_os_fpu.library] [] [Fail]
    [356] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library] [Read] [Fail]
    [357] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library] [Read] [Fail]
    [358] [ramlib] [Load] [libs/softlogik_os_fpu.library] [] [Fail]
    [359] [ramlib] [Open] [libs/softlogik_os_fpu.library] [Read] [Fail]
    [360] [ramlib] [Open] [libs/softlogik_os_fpu.library] [Read] [Fail]
    [361] [PageStream4] [Open] [SOFTLOGIK:printers/Hewlett-Packard.printer] [Read] [OK]
    [362] [PageStream4] [Open] [SOFTLOGIK:printers/Hewlett-Packard.printer] [Read] [OK]
    [363] [PageStream4] [Open] [SOFTLOGIK:printers/XPD/HPModels] [Read] [OK]
    [364] [PageStream4] [NewLoad] [SOFTLOGIK:Printers/Fargo.printer] [] [OK]
    [365] [PageStream4] [Open] [SOFTLOGIK:Printers/Fargo.printer] [Read] [OK]
    [366] [PageStream4] [Open] [SOFTLOGIK:Printers/Fargo.printer] [Read] [OK]
    [367] [PageStream4] [Open] [SOFTLOGIK:printers/Fargo.printer] [Read] [OK]
    [368] [PageStream4] [Open] [SOFTLOGIK:printers/Fargo.printer] [Read] [OK]
    [369] [PageStream4] [NewLoad] [SOFTLOGIK:Printers/Epson.printer] [] [OK]
    [370] [PageStream4] [Open] [SOFTLOGIK:Printers/Epson.printer] [Read] [OK]
    [371] [PageStream4] [Open] [SOFTLOGIK:Printers/Epson.printer] [Read] [OK]
    [372] [ramlib] [Load] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [] [Fail]
    [373] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [374] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [375] [ramlib] [Load] [SOFTLOGIK:libs/softlogik_os_fpu.library] [] [Fail]
    [376] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library] [Read] [Fail]
    [377] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library] [Read] [Fail]
    [378] [ramlib] [Load] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [] [Fail]
    [379] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [380] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [381] [ramlib] [Load] [libs/softlogik_os_fpu.library.elf] [] [Fail]
    [382] [ramlib] [Open] [libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [383] [ramlib] [Open] [libs/softlogik_os_fpu.library.elf] [Read] [Fail]
    [384] [ramlib] [Load] [SOFTLOGIK:libs/softlogik_os_fpu.library] [] [Fail]
    [385] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library] [Read] [Fail]
    [386] [ramlib] [Open] [SOFTLOGIK:libs/softlogik_os_fpu.library] [Read] [Fail]
    [387] [ramlib] [Load] [libs/softlogik_os_fpu.library] [] [Fail]
    [388] [ramlib] [Open] [libs/softlogik_os_fpu.library] [Read] [Fail]
    [389] [ramlib] [Open] [libs/softlogik_os_fpu.library] [Read] [Fail]
    [390] [PageStream4] [Open] [SOFTLOGIK:printers/Epson.printer] [Read] [OK]
    [391] [PageStream4] [Open] [SOFTLOGIK:printers/Epson.printer] [Read] [OK]
    [392] [PageStream4] [Open] [SOFTLOGIK:printers/XPD/EpsonModels] [Read] [OK]
    [393] [PageStream4] [Open] [SOFTLOGIK:printers/PostScript.printer] [Read] [OK]
    [394] [PageStream4] [Open] [SOFTLOGIK:printers/PostScript.printer] [Read] [OK]
    [395] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/WordworthDoc.dfilter] [] [OK]
    [396] [PageStream4] [Open] [SOFTLOGIK:Filters/WordworthDoc.dfilter] [Read] [OK]
    [397] [PageStream4] [Open] [SOFTLOGIK:Filters/WordworthDoc.dfilter] [Read] [OK]
    [398] [PageStream4] [Open] [SOFTLOGIK:filters/WordworthDoc.dfilter] [Read] [OK]
    [399] [PageStream4] [Open] [SOFTLOGIK:filters/WordworthDoc.dfilter] [Read] [OK]
    [400] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/Wordworth.tfilter] [] [OK]
    [401] [PageStream4] [Open] [SOFTLOGIK:Filters/Wordworth.tfilter] [Read] [OK]
    [402] [PageStream4] [Open] [SOFTLOGIK:Filters/Wordworth.tfilter] [Read] [OK]
    [403] [PageStream4] [Open] [SOFTLOGIK:filters/Wordworth.tfilter] [Read] [OK]
    [404] [PageStream4] [Open] [SOFTLOGIK:filters/Wordworth.tfilter] [Read] [OK]
    [405] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/WordPerfect.tfilter] [] [OK]
    [406] [PageStream4] [Open] [SOFTLOGIK:Filters/WordPerfect.tfilter] [Read] [OK]
    [407] [PageStream4] [Open] [SOFTLOGIK:Filters/WordPerfect.tfilter] [Read] [OK]
    [408] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/TIFF.gfilter] [] [OK]
    [409] [PageStream4] [Open] [SOFTLOGIK:Filters/TIFF.gfilter] [Read] [OK]
    [410] [PageStream4] [Open] [SOFTLOGIK:Filters/TIFF.gfilter] [Read] [OK]
    [411] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/RTF.tfilter] [] [OK]
    [412] [PageStream4] [Open] [SOFTLOGIK:Filters/RTF.tfilter] [Read] [OK]
    [413] [PageStream4] [Open] [SOFTLOGIK:Filters/RTF.tfilter] [Read] [OK]
    [414] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/ProWrite.tfilter] [] [OK]
    [415] [PageStream4] [Open] [SOFTLOGIK:Filters/ProWrite.tfilter] [Read] [OK]
    [416] [PageStream4] [Open] [SOFTLOGIK:Filters/ProWrite.tfilter] [Read] [OK]
    [417] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/ProPage.dfilter] [] [OK]
    [418] [PageStream4] [Open] [SOFTLOGIK:Filters/ProPage.dfilter] [Read] [OK]
    [419] [PageStream4] [Open] [SOFTLOGIK:Filters/ProPage.dfilter] [Read] [OK]
    [420] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/ProDrawClip.gfilter] [] [OK]
    [421] [PageStream4] [Open] [SOFTLOGIK:Filters/ProDrawClip.gfilter] [Read] [OK]
    [422] [PageStream4] [Open] [SOFTLOGIK:Filters/ProDrawClip.gfilter] [Read] [OK]
    [423] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/PICT.gfilter] [] [OK]
    [424] [PageStream4] [Open] [SOFTLOGIK:Filters/PICT.gfilter] [Read] [OK]
    [425] [PageStream4] [Open] [SOFTLOGIK:Filters/PICT.gfilter] [Read] [OK]
    [426] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/PICT-Bitmap.gfilter] [] [OK]
    [427] [PageStream4] [Open] [SOFTLOGIK:Filters/PICT-Bitmap.gfilter] [Read] [OK]
    [428] [PageStream4] [Open] [SOFTLOGIK:Filters/PICT-Bitmap.gfilter] [Read] [OK]
    [429] [PageStream4] [Open] [SOFTLOGIK:filters/PICT-Bitmap.gfilter] [Read] [OK]
    [430] [PageStream4] [Open] [SOFTLOGIK:filters/PICT-Bitmap.gfilter] [Read] [OK]
    [431] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/PCX.gfilter] [] [OK]
    [432] [PageStream4] [Open] [SOFTLOGIK:Filters/PCX.gfilter] [Read] [OK]
    [433] [PageStream4] [Open] [SOFTLOGIK:Filters/PCX.gfilter] [Read] [OK]
    [434] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/PageStream2.dfilter] [] [OK]
    [435] [PageStream4] [Open] [SOFTLOGIK:Filters/PageStream2.dfilter] [Read] [OK]
    [436] [PageStream4] [Open] [SOFTLOGIK:Filters/PageStream2.dfilter] [Read] [OK]
    [437] [PageStream4] [Open] [SOFTLOGIK:filters/PageStream2.dfilter] [Read] [OK]
    [438] [PageStream4] [Open] [SOFTLOGIK:filters/PageStream2.dfilter] [Read] [OK]
    [439] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/MacPaint.gfilter] [] [OK]
    [440] [PageStream4] [Open] [SOFTLOGIK:Filters/MacPaint.gfilter] [Read] [OK]
    [441] [PageStream4] [Open] [SOFTLOGIK:Filters/MacPaint.gfilter] [Read] [OK]
    [442] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/JPEG.gfilter] [] [OK]
    [443] [PageStream4] [Open] [SOFTLOGIK:Filters/JPEG.gfilter] [Read] [OK]
    [444] [PageStream4] [Open] [SOFTLOGIK:Filters/JPEG.gfilter] [Read] [OK]
    [445] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [446] [PageStream4] [Open] [NIL:] [Read] [OK]
    [447] [PageStream4] [Open] [NIL:] [Write] [OK]
    [448] [PageStream4] [Open] [*] [Read] [OK]
    [449] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/IllustratorEPS.gfilter] [] [OK]
    [450] [PageStream4] [Open] [SOFTLOGIK:Filters/IllustratorEPS.gfilter] [Read] [OK]
    [451] [PageStream4] [Open] [SOFTLOGIK:Filters/IllustratorEPS.gfilter] [Read] [OK]
    [452] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/IFFILUS.gfilter] [] [OK]
    [453] [PageStream4] [Open] [SOFTLOGIK:Filters/IFFILUS.gfilter] [Read] [OK]
    [454] [PageStream4] [Open] [SOFTLOGIK:Filters/IFFILUS.gfilter] [Read] [OK]
    [455] [PageStream4] [Open] [SOFTLOGIK:filters/IFFILUS.gfilter] [Read] [OK]
    [456] [PageStream4] [Open] [SOFTLOGIK:filters/IFFILUS.gfilter] [Read] [OK]
    [457] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/IFFILBM.gfilter] [] [OK]
    [458] [PageStream4] [Open] [SOFTLOGIK:Filters/IFFILBM.gfilter] [Read] [OK]
    [459] [PageStream4] [Open] [SOFTLOGIK:Filters/IFFILBM.gfilter] [Read] [OK]
    [460] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/IFFFTXT.tfilter] [] [OK]
    [461] [PageStream4] [Open] [SOFTLOGIK:Filters/IFFFTXT.tfilter] [Read] [OK]
    [462] [PageStream4] [Open] [SOFTLOGIK:Filters/IFFFTXT.tfilter] [Read] [OK]
    [463] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/IFFDR2D.gfilter] [] [OK]
    [464] [PageStream4] [Open] [SOFTLOGIK:Filters/IFFDR2D.gfilter] [Read] [OK]
    [465] [PageStream4] [Open] [SOFTLOGIK:Filters/IFFDR2D.gfilter] [Read] [OK]
    [466] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/IFFDOC.dfilter] [] [OK]
    [467] [PageStream4] [Open] [SOFTLOGIK:Filters/IFFDOC.dfilter] [Read] [OK]
    [468] [PageStream4] [Open] [SOFTLOGIK:Filters/IFFDOC.dfilter] [Read] [OK]
    [469] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [470] [PageStream4] [Open] [NIL:] [Read] [OK]
    [471] [PageStream4] [Open] [NIL:] [Write] [OK]
    [472] [PageStream4] [Open] [*] [Read] [OK]
    [473] [PageStream4] [Open] [SOFTLOGIK:filters/IFFDOC.dfilter] [Read] [OK]
    [474] [PageStream4] [Open] [SOFTLOGIK:filters/IFFDOC.dfilter] [Read] [OK]
    [475] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/IFFCTXT.tfilter] [] [OK]
    [476] [PageStream4] [Open] [SOFTLOGIK:Filters/IFFCTXT.tfilter] [Read] [OK]
    [477] [PageStream4] [Open] [SOFTLOGIK:Filters/IFFCTXT.tfilter] [Read] [OK]
    [478] [PageStream4] [Open] [SOFTLOGIK:filters/IFFCTXT.tfilter] [Read] [OK]
    [479] [PageStream4] [Open] [SOFTLOGIK:filters/IFFCTXT.tfilter] [Read] [OK]
    [480] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/HTML.tfilter] [] [OK]
    [481] [PageStream4] [Open] [SOFTLOGIK:Filters/HTML.tfilter] [Read] [OK]
    [482] [PageStream4] [Open] [SOFTLOGIK:Filters/HTML.tfilter] [Read] [OK]
    [483] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/GIF.gfilter] [] [OK]
    [484] [PageStream4] [Open] [SOFTLOGIK:Filters/GIF.gfilter] [Read] [OK]
    [485] [PageStream4] [Open] [SOFTLOGIK:Filters/GIF.gfilter] [Read] [OK]
    [486] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/FinalWriter.tfilter] [] [OK]
    [487] [PageStream4] [Open] [SOFTLOGIK:Filters/FinalWriter.tfilter] [Read] [OK]
    [488] [PageStream4] [Open] [SOFTLOGIK:Filters/FinalWriter.tfilter] [Read] [OK]
    [489] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/Excellence.tfilter] [] [OK]
    [490] [PageStream4] [Open] [SOFTLOGIK:Filters/Excellence.tfilter] [Read] [OK]
    [491] [PageStream4] [Open] [SOFTLOGIK:Filters/Excellence.tfilter] [Read] [OK]
    [492] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/EPS.gfilter] [] [OK]
    [493] [PageStream4] [Open] [SOFTLOGIK:Filters/EPS.gfilter] [Read] [OK]
    [494] [PageStream4] [Open] [SOFTLOGIK:Filters/EPS.gfilter] [Read] [OK]
    [495] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/BMP.gfilter] [] [OK]
    [496] [PageStream4] [Open] [SOFTLOGIK:Filters/BMP.gfilter] [Read] [OK]
    [497] [PageStream4] [Open] [SOFTLOGIK:Filters/BMP.gfilter] [Read] [OK]
    [498] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/ASCII.tfilter] [] [OK]
    [499] [PageStream4] [Open] [SOFTLOGIK:Filters/ASCII.tfilter] [Read] [OK]
    [500] [PageStream4] [Open] [SOFTLOGIK:Filters/ASCII.tfilter] [Read] [OK]
    [501] [PageStream4] [NewLoad] [SOFTLOGIK:Filters/ArtExpressionEPS.gfilter] [] [OK]
    [502] [PageStream4] [Open] [SOFTLOGIK:Filters/ArtExpressionEPS.gfilter] [Read] [OK]
    [503] [PageStream4] [Open] [SOFTLOGIK:Filters/ArtExpressionEPS.gfilter] [Read] [OK]
    [504] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/PageStream.codes] [] [OK]
    [505] [PageStream4] [Open] [SOFTLOGIK:Engines/PageStream.codes] [Read] [OK]
    [506] [PageStream4] [Open] [SOFTLOGIK:Engines/PageStream.codes] [Read] [OK]
    [507] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/PageMaker.codes] [] [OK]
    [508] [PageStream4] [Open] [SOFTLOGIK:Engines/PageMaker.codes] [Read] [OK]
    [509] [PageStream4] [Open] [SOFTLOGIK:Engines/PageMaker.codes] [Read] [OK]
    [510] [PageStream4] [NewLoad] [SOFTLOGIK:Special/clipboard] [] [OK]
    [511] [PageStream4] [Open] [SOFTLOGIK:Special/clipboard] [Read] [OK]
    [512] [PageStream4] [Open] [SOFTLOGIK:Special/clipboard] [Read] [OK]
    [513] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Trace.effect] [] [OK]
    [514] [PageStream4] [Open] [SOFTLOGIK:Effects/Trace.effect] [Read] [OK]
    [515] [PageStream4] [Open] [SOFTLOGIK:Effects/Trace.effect] [Read] [OK]
    [516] [PageStream4] [Open] [SOFTLOGIK:effects/Trace.effect] [Read] [OK]
    [517] [PageStream4] [Open] [SOFTLOGIK:effects/Trace.effect] [Read] [OK]
    [518] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Tile.effect] [] [OK]
    [519] [PageStream4] [Open] [SOFTLOGIK:Effects/Tile.effect] [Read] [OK]
    [520] [PageStream4] [Open] [SOFTLOGIK:Effects/Tile.effect] [Read] [OK]
    [521] [PageStream4] [Open] [SOFTLOGIK:effects/Tile.effect] [Read] [OK]
    [522] [PageStream4] [Open] [SOFTLOGIK:effects/Tile.effect] [Read] [OK]
    [523] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Threshold.effect] [] [OK]
    [524] [PageStream4] [Open] [SOFTLOGIK:Effects/Threshold.effect] [Read] [OK]
    [525] [PageStream4] [Open] [SOFTLOGIK:Effects/Threshold.effect] [Read] [OK]
    [526] [PageStream4] [Open] [SOFTLOGIK:effects/Threshold.effect] [Read] [OK]
    [527] [PageStream4] [Open] [SOFTLOGIK:effects/Threshold.effect] [Read] [OK]
    [528] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Solarize.effect] [] [OK]
    [529] [PageStream4] [Open] [SOFTLOGIK:Effects/Solarize.effect] [Read] [OK]
    [530] [PageStream4] [Open] [SOFTLOGIK:Effects/Solarize.effect] [Read] [OK]
    [531] [PageStream4] [Open] [SOFTLOGIK:effects/Solarize.effect] [Read] [OK]
    [532] [PageStream4] [Open] [SOFTLOGIK:effects/Solarize.effect] [Read] [OK]
    [533] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Sharpen.effect] [] [OK]
    [534] [PageStream4] [Open] [SOFTLOGIK:Effects/Sharpen.effect] [Read] [OK]
    [535] [PageStream4] [Open] [SOFTLOGIK:Effects/Sharpen.effect] [Read] [OK]
    [536] [PageStream4] [Open] [SOFTLOGIK:effects/Sharpen.effect] [Read] [OK]
    [537] [PageStream4] [Open] [SOFTLOGIK:effects/Sharpen.effect] [Read] [OK]
    [538] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/ReduceNoise.effect] [] [OK]
    [539] [PageStream4] [Open] [SOFTLOGIK:Effects/ReduceNoise.effect] [Read] [OK]
    [540] [PageStream4] [Open] [SOFTLOGIK:Effects/ReduceNoise.effect] [Read] [OK]
    [541] [PageStream4] [Open] [SOFTLOGIK:effects/ReduceNoise.effect] [Read] [OK]
    [542] [PageStream4] [Open] [SOFTLOGIK:effects/ReduceNoise.effect] [Read] [OK]
    [543] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Pixelize.effect] [] [OK]
    [544] [PageStream4] [Open] [SOFTLOGIK:Effects/Pixelize.effect] [Read] [OK]
    [545] [PageStream4] [Open] [SOFTLOGIK:Effects/Pixelize.effect] [Read] [OK]
    [546] [PageStream4] [Open] [SOFTLOGIK:effects/Pixelize.effect] [Read] [OK]
    [547] [PageStream4] [Open] [SOFTLOGIK:effects/Pixelize.effect] [Read] [OK]
    [548] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Negative.effect] [] [OK]
    [549] [PageStream4] [Open] [SOFTLOGIK:Effects/Negative.effect] [Read] [OK]
    [550] [PageStream4] [Open] [SOFTLOGIK:Effects/Negative.effect] [Read] [OK]
    [551] [PageStream4] [Open] [SOFTLOGIK:effects/Negative.effect] [Read] [OK]
    [552] [PageStream4] [Open] [SOFTLOGIK:effects/Negative.effect] [Read] [OK]
    [553] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Minimum.effect] [] [OK]
    [554] [PageStream4] [Open] [SOFTLOGIK:Effects/Minimum.effect] [Read] [OK]
    [555] [PageStream4] [Open] [SOFTLOGIK:Effects/Minimum.effect] [Read] [OK]
    [556] [PageStream4] [Open] [SOFTLOGIK:effects/Minimum.effect] [Read] [OK]
    [557] [PageStream4] [Open] [SOFTLOGIK:effects/Minimum.effect] [Read] [OK]
    [558] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Median.effect] [] [OK]
    [559] [PageStream4] [Open] [SOFTLOGIK:Effects/Median.effect] [Read] [OK]
    [560] [PageStream4] [Open] [SOFTLOGIK:Effects/Median.effect] [Read] [OK]
    [561] [PageStream4] [Open] [SOFTLOGIK:effects/Median.effect] [Read] [OK]
    [562] [PageStream4] [Open] [SOFTLOGIK:effects/Median.effect] [Read] [OK]
    [563] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Maximum.effect] [] [OK]
    [564] [PageStream4] [Open] [SOFTLOGIK:Effects/Maximum.effect] [Read] [OK]
    [565] [PageStream4] [Open] [SOFTLOGIK:Effects/Maximum.effect] [Read] [OK]
    [566] [PageStream4] [Open] [SOFTLOGIK:effects/Maximum.effect] [Read] [OK]
    [567] [PageStream4] [Open] [SOFTLOGIK:effects/Maximum.effect] [Read] [OK]
    [568] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/HSB.effect] [] [OK]
    [569] [PageStream4] [Open] [SOFTLOGIK:Effects/HSB.effect] [Read] [OK]
    [570] [PageStream4] [Open] [SOFTLOGIK:Effects/HSB.effect] [Read] [OK]
    [571] [PageStream4] [Open] [SOFTLOGIK:effects/HSB.effect] [Read] [OK]
    [572] [PageStream4] [Open] [SOFTLOGIK:effects/HSB.effect] [Read] [OK]
    [573] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Histogram.effect] [] [OK]
    [574] [PageStream4] [Open] [SOFTLOGIK:Effects/Histogram.effect] [Read] [OK]
    [575] [PageStream4] [Open] [SOFTLOGIK:Effects/Histogram.effect] [Read] [OK]
    [576] [PageStream4] [Open] [SOFTLOGIK:effects/Histogram.effect] [Read] [OK]
    [577] [PageStream4] [Open] [SOFTLOGIK:effects/Histogram.effect] [Read] [OK]
    [578] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Gamma.effect] [] [OK]
    [579] [PageStream4] [Open] [SOFTLOGIK:Effects/Gamma.effect] [Read] [OK]
    [580] [PageStream4] [Open] [SOFTLOGIK:Effects/Gamma.effect] [Read] [OK]
    [581] [PageStream4] [Open] [SOFTLOGIK:effects/Gamma.effect] [Read] [OK]
    [582] [PageStream4] [Open] [SOFTLOGIK:effects/Gamma.effect] [Read] [OK]
    [583] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Equalize.effect] [] [OK]
    [584] [PageStream4] [Open] [SOFTLOGIK:Effects/Equalize.effect] [Read] [OK]
    [585] [PageStream4] [Open] [SOFTLOGIK:Effects/Equalize.effect] [Read] [OK]
    [586] [PageStream4] [Open] [SOFTLOGIK:effects/Equalize.effect] [Read] [OK]
    [587] [PageStream4] [Open] [SOFTLOGIK:effects/Equalize.effect] [Read] [OK]
    [588] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Emboss.effect] [] [OK]
    [589] [PageStream4] [Open] [SOFTLOGIK:Effects/Emboss.effect] [Read] [OK]
    [590] [PageStream4] [Open] [SOFTLOGIK:Effects/Emboss.effect] [Read] [OK]
    [591] [PageStream4] [Open] [SOFTLOGIK:effects/Emboss.effect] [Read] [OK]
    [592] [PageStream4] [Open] [SOFTLOGIK:effects/Emboss.effect] [Read] [OK]
    [593] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Convolve.effect] [] [OK]
    [594] [PageStream4] [Open] [SOFTLOGIK:Effects/Convolve.effect] [Read] [OK]
    [595] [PageStream4] [Open] [SOFTLOGIK:Effects/Convolve.effect] [Read] [OK]
    [596] [PageStream4] [Open] [SOFTLOGIK:effects/Convolve.effect] [Read] [OK]
    [597] [PageStream4] [Open] [SOFTLOGIK:effects/Convolve.effect] [Read] [OK]
    [598] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Contrast.effect] [] [OK]
    [599] [PageStream4] [Open] [SOFTLOGIK:Effects/Contrast.effect] [Read] [OK]
    [600] [PageStream4] [Open] [SOFTLOGIK:Effects/Contrast.effect] [Read] [OK]
    [601] [PageStream4] [Open] [SOFTLOGIK:effects/Contrast.effect] [Read] [OK]
    [602] [PageStream4] [Open] [SOFTLOGIK:effects/Contrast.effect] [Read] [OK]
    [603] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Brightness.effect] [] [OK]
    [604] [PageStream4] [Open] [SOFTLOGIK:Effects/Brightness.effect] [Read] [OK]
    [605] [PageStream4] [Open] [SOFTLOGIK:Effects/Brightness.effect] [Read] [OK]
    [606] [PageStream4] [Open] [SOFTLOGIK:effects/Brightness.effect] [Read] [OK]
    [607] [PageStream4] [Open] [SOFTLOGIK:effects/Brightness.effect] [Read] [OK]
    [608] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Blur.effect] [] [OK]
    [609] [PageStream4] [Open] [SOFTLOGIK:Effects/Blur.effect] [Read] [OK]
    [610] [PageStream4] [Open] [SOFTLOGIK:Effects/Blur.effect] [Read] [OK]
    [611] [PageStream4] [Open] [SOFTLOGIK:effects/Blur.effect] [Read] [OK]
    [612] [PageStream4] [Open] [SOFTLOGIK:effects/Blur.effect] [Read] [OK]
    [613] [PageStream4] [NewLoad] [SOFTLOGIK:Effects/Average.effect] [] [OK]
    [614] [PageStream4] [Open] [SOFTLOGIK:Effects/Average.effect] [Read] [OK]
    [615] [PageStream4] [Open] [SOFTLOGIK:Effects/Average.effect] [Read] [OK]
    [616] [PageStream4] [Open] [SOFTLOGIK:effects/Average.effect] [Read] [OK]
    [617] [PageStream4] [Open] [SOFTLOGIK:effects/Average.effect] [Read] [OK]
    [618] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Svenska.language] [] [OK]
    [619] [PageStream4] [Open] [SOFTLOGIK:Engines/Svenska.language] [Read] [OK]
    [620] [PageStream4] [Open] [SOFTLOGIK:Engines/Svenska.language] [Read] [OK]
    [621] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [622] [PageStream4] [Open] [NIL:] [Read] [OK]
    [623] [PageStream4] [Open] [NIL:] [Write] [OK]
    [624] [PageStream4] [Open] [*] [Read] [OK]
    [625] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Suomi.language] [] [OK]
    [626] [PageStream4] [Open] [SOFTLOGIK:Engines/Suomi.language] [Read] [OK]
    [627] [PageStream4] [Open] [SOFTLOGIK:Engines/Suomi.language] [Read] [OK]
    [628] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [629] [PageStream4] [Open] [NIL:] [Read] [OK]
    [630] [PageStream4] [Open] [NIL:] [Write] [OK]
    [631] [PageStream4] [Open] [*] [Read] [OK]
    [632] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Srpski.language] [] [OK]
    [633] [PageStream4] [Open] [SOFTLOGIK:Engines/Srpski.language] [Read] [OK]
    [634] [PageStream4] [Open] [SOFTLOGIK:Engines/Srpski.language] [Read] [OK]
    [635] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [636] [PageStream4] [Open] [NIL:] [Read] [OK]
    [637] [PageStream4] [Open] [NIL:] [Write] [OK]
    [638] [PageStream4] [Open] [*] [Read] [OK]
    [639] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Slovenian.language] [] [OK]
    [640] [PageStream4] [Open] [SOFTLOGIK:Engines/Slovenian.language] [Read] [OK]
    [641] [PageStream4] [Open] [SOFTLOGIK:Engines/Slovenian.language] [Read] [OK]
    [642] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [643] [PageStream4] [Open] [NIL:] [Read] [OK]
    [644] [PageStream4] [Open] [NIL:] [Write] [OK]
    [645] [PageStream4] [Open] [*] [Read] [OK]
    [646] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Polski.language] [] [OK]
    [647] [PageStream4] [Open] [SOFTLOGIK:Engines/Polski.language] [Read] [OK]
    [648] [PageStream4] [Open] [SOFTLOGIK:Engines/Polski.language] [Read] [OK]
    [649] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [650] [PageStream4] [Open] [NIL:] [Read] [OK]
    [651] [PageStream4] [Open] [NIL:] [Write] [OK]
    [652] [PageStream4] [Open] [*] [Read] [OK]
    [653] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Norsk.language] [] [OK]
    [654] [PageStream4] [Open] [SOFTLOGIK:Engines/Norsk.language] [Read] [OK]
    [655] [PageStream4] [Open] [SOFTLOGIK:Engines/Norsk.language] [Read] [OK]
    [656] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [657] [PageStream4] [Open] [NIL:] [Read] [OK]
    [658] [PageStream4] [Open] [NIL:] [Write] [OK]
    [659] [PageStream4] [Open] [*] [Read] [OK]
    [660] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Nederlands.language] [] [OK]
    [661] [PageStream4] [Open] [SOFTLOGIK:Engines/Nederlands.language] [Read] [OK]
    [662] [PageStream4] [Open] [SOFTLOGIK:Engines/Nederlands.language] [Read] [OK]
    [663] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [664] [PageStream4] [Open] [NIL:] [Read] [OK]
    [665] [PageStream4] [Open] [NIL:] [Write] [OK]
    [666] [PageStream4] [Open] [*] [Read] [OK]
    [667] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Magyar.language] [] [OK]
    [668] [PageStream4] [Open] [SOFTLOGIK:Engines/Magyar.language] [Read] [OK]
    [669] [PageStream4] [Open] [SOFTLOGIK:Engines/Magyar.language] [Read] [OK]
    [670] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [671] [PageStream4] [Open] [NIL:] [Read] [OK]
    [672] [PageStream4] [Open] [NIL:] [Write] [OK]
    [673] [PageStream4] [Open] [*] [Read] [OK]
    [674] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Italiano.language] [] [OK]
    [675] [PageStream4] [Open] [SOFTLOGIK:Engines/Italiano.language] [Read] [OK]
    [676] [PageStream4] [Open] [SOFTLOGIK:Engines/Italiano.language] [Read] [OK]
    [677] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [678] [PageStream4] [Open] [NIL:] [Read] [OK]
    [679] [PageStream4] [Open] [NIL:] [Write] [OK]
    [680] [PageStream4] [Open] [*] [Read] [OK]
    [681] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Francais.language] [] [OK]
    [682] [PageStream4] [Open] [SOFTLOGIK:Engines/Francais.language] [Read] [OK]
    [683] [PageStream4] [Open] [SOFTLOGIK:Engines/Francais.language] [Read] [OK]
    [684] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [685] [PageStream4] [Open] [NIL:] [Read] [OK]
    [686] [PageStream4] [Open] [NIL:] [Write] [OK]
    [687] [PageStream4] [Open] [*] [Read] [OK]
    [688] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Espanol.language] [] [OK]
    [689] [PageStream4] [Open] [SOFTLOGIK:Engines/Espanol.language] [Read] [OK]
    [690] [PageStream4] [Open] [SOFTLOGIK:Engines/Espanol.language] [Read] [OK]
    [691] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [692] [PageStream4] [Open] [NIL:] [Read] [OK]
    [693] [PageStream4] [Open] [NIL:] [Write] [OK]
    [694] [PageStream4] [Open] [*] [Read] [OK]
    [695] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Deutsch.language] [] [OK]
    [696] [PageStream4] [Open] [SOFTLOGIK:Engines/Deutsch.language] [Read] [OK]
    [697] [PageStream4] [Open] [SOFTLOGIK:Engines/Deutsch.language] [Read] [OK]
    [698] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [699] [PageStream4] [Open] [NIL:] [Read] [OK]
    [700] [PageStream4] [Open] [NIL:] [Write] [OK]
    [701] [PageStream4] [Open] [*] [Read] [OK]
    [702] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Dansk.language] [] [OK]
    [703] [PageStream4] [Open] [SOFTLOGIK:Engines/Dansk.language] [Read] [OK]
    [704] [PageStream4] [Open] [SOFTLOGIK:Engines/Dansk.language] [Read] [OK]
    [705] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [706] [PageStream4] [Open] [NIL:] [Read] [OK]
    [707] [PageStream4] [Open] [NIL:] [Write] [OK]
    [708] [PageStream4] [Open] [*] [Read] [OK]
    [709] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/British.language] [] [OK]
    [710] [PageStream4] [Open] [SOFTLOGIK:Engines/British.language] [Read] [OK]
    [711] [PageStream4] [Open] [SOFTLOGIK:Engines/British.language] [Read] [OK]
    [712] [PageStream4] [Open] [con:10/10/320/80/Output/auto/close/wait] [Write] [OK]
    [713] [PageStream4] [Open] [NIL:] [Read] [OK]
    [714] [PageStream4] [Open] [NIL:] [Write] [OK]
    [715] [PageStream4] [Open] [*] [Read] [OK]
    [716] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/American.language] [] [OK]
    [717] [PageStream4] [Open] [SOFTLOGIK:Engines/American.language] [Read] [OK]
    [718] [PageStream4] [Open] [SOFTLOGIK:Engines/American.language] [Read] [OK]
    [719] [PageStream4] [Open] [Scripts/PageStream4.scripts] [Read] [OK]
    [720] [PageStream4] [Open] [SOFTLOGIK:colors/Crayons.library] [Read] [OK]
    [721] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/TextFX.extension] [] [OK]
    [722] [PageStream4] [Open] [SOFTLOGIK:Engines/TextFX.extension] [Read] [OK]
    [723] [PageStream4] [Open] [SOFTLOGIK:Engines/TextFX.extension] [Read] [OK]
    [724] [PageStream4] [NewLoad] [SOFTLOGIK:Engines/Borders.extension] [] [OK]
    [725] [PageStream4] [Open] [SOFTLOGIK:Engines/Borders.extension] [Read] [OK]
    [726] [PageStream4] [Open] [SOFTLOGIK:Engines/Borders.extension] [Read] [OK]
    [727] [PageStream4] [Open] [SOFTLOGIK:engines/Borders.extension] [Read] [OK]
    [728] [PageStream4] [Open] [SOFTLOGIK:engines/Borders.extension] [Read] [OK]
    [729] [PageStream4] [Open] [SOFTLOGIK:engines/Borders.extension] [Read] [OK]
    [730] [PageStream4] [Open] [SOFTLOGIK:engines/Borders.extension] [Read] [OK]
    [731] [PageStream4] [Open] [SOFTLOGIK:engines/Borders.extension] [Read] [OK]
    [732] [« Skin Manager »] [ChangeDir] [MorphOS:MorphOS/Prefs/Skins/Mahalaxmi] [] []
    [733] [« Skin Manager »] [Open] [MenuTitlebar] [Read] [OK]
    [734] [« Skin Manager »] [ChangeDir] [SYS:] [] []
    [735] [« Skin Manager »] [ChangeDir] [MorphOS:MorphOS/Prefs/Skins/Mahalaxmi] [] []
    [736] [« Skin Manager »] [Open] [MenuBackground] [Read] [OK]
    [737] [« Skin Manager »] [ChangeDir] [SYS:] [] []
    [738] [PageStream4] [Open] [PageStream:Help/tips] [Read] [OK]
  • »12.09.14 - 01:12
  • rms
    rms
    Posts: 603 from 2004/11/27
    I think there is no need to ask for a refund because PGS 4 works fine here since about 15 years! It must be something else... hmmm...
    You need to leave CSets dir where it ise but create a subdir in CSets "disabled" and move all the content in there. This is /CSets/disabled/ and the files
    Here are the assigns that I have in user-startup:
    ;BEGIN PageStream
    Assign PageStream: "System:PageStream" DEFER
    Assign PageStream3: "System:PageStream" DEFER
    Assign PageStream4: "System:PageStream" DEFER
    Assign SoftLogik: "PageStream:SoftLogik" DEFER
    Assign Fonts: "PageStream:SoftLogik/Fonts" ADD
    ;END PageStream
    MorphOS 3.4 works fine with PGS 4
    No need to copy anything else then the original dirs and files in the Softlogik dir, just leave the fonts in the fonts dir.
    In case you have an HHV.prefs file, please delete it. I'm not sure anymore (long time ago) but I remember that there where some issue with that.
    What we finally could do is, that I send you my prefs file and you try.
    Regards
    Christoph
  • »12.09.14 - 02:21
    Posts: 12408 from 2003/5/22
    Derek? ;-)
  • »12.09.14 - 06:23
    Kaczus
    Posts: 199 from 2003/9/6
    16bit screen depts
    Setting the fonts
    It is public own screen? I've used Pagestream 4 since morphos 1.0.
    Kaczus/BlaBla & AUG-Lodz Happy Pegasos User
  • »12.09.14 - 07:39
    NewSense
    I said all along that this issue is a 'pig' (apologies to any 'pigs' out there) of a problem to fix.
    Like you, I spent ages trying to figure out what would make it work, and I am not sure just one single thing made it work correctly, but it is working OK on my system, so I don't want to mess with it to upset it all over again.
    I KNOW it is possible to get it working, but just try everything that is mentioned, and then a few things besides, if you can think of anything else to alter slightly, and then see if that gets it working.
    I really wish I could say ........ it's this item/setting you need to change, ... BUT I am not sure that what I say is definitely what was the problem for me, but all the things that have been mentioned to you, were mentioned to me, and EVENTUALLY I got it working OK ... you will as well, EVENTUALLY. ;-)
    If anyone works out what thing(s) it is that need to be changed to get it working after the standard Installer routine, then please say, as it is something worth knowing - for any future users information/knowledge.
  • »12.09.14 - 14:06
