Morphos 2.2 and Pagestream 4.1.5.6
    Kaczus
    Posts: 199 from 2003/9/6
    Hi! After installing MorphOS 2.2 my Pagestream stoped working. I try to find a reason of this problem.
    I've catched only this log: http://kaczus.republika.pl/logs/pgs_and_mos2_2.txt
    Can You help me with this problem?
    [ Edited by Kaczus on 2009/1/16 19:27 ]
    Kaczus/BlaBla & AUG-Lodz Happy Pegasos User
  • »16.01.09 - 16:26
    amiga4001
    Posts: 449 from 2006/11/16
    Pagestream works here?ok.(pagestream 4.1.2 MOS2.2).
    Maybe there are some libs missing?
  • »16.01.09 - 18:07
    Stany
    Posts: 26 from 2003/4/28
    Hoi Amiga4001 ,
    I have also problem to start Pagestream on Morphos 2.2 .
    at Mophos 1.4 work fine .
    Pagestream 4.1.3.4
    can you tell wath i missing ?
  • »16.01.09 - 19:37
    Kaczus
    Unfortunately, on download page there are only 4.1.5.6pro and 4.0.9, but 4.0.9 is not pro version.
    There are also 5.x versions, but this version is still unusble...
  • »16.01.09 - 19:42
  • rms
    rms
    Posts: 603 from 2004/11/27
    @ Kaczus
    PageStream 4.1.5.6 is working fine here under MorphOS 2.2
    The only thing I had to do in order that PageStream NEVER crashes on startup is to disable
    completely the contents of the "CSet"-folder. Try the following, which worked for me, create a
    "disalbled"-folder in the folder "CSet" (which is in PageStream/Softlogik/) and then move all the
    files in this "Disabled"-folder.
    I think this has something to do with codeset handling or so...
    Hope this helps
    Regards
    Christoph
  • »17.01.09 - 05:56
    _bigdan_
    Posts: 70 from 2009/1/7
    Same thing here. Need to disable Cset drawer to start PGS.
    Arnaud aka bigdan^amigaimpact.org
  • »17.01.09 - 08:04
    Kaczus
    Yes,You are right... I've deleted CSets drawer, create newone, and insert only some of charsets and it works. Thx! :)
  • »17.01.09 - 09:59
    _coliN_
    Posts: 69 from 2003/4/30
    In the past I have tried it also several times with no good results,
    but if you boot with the MOS install cd (2.2) and start PGS 5, it works much much better... Waiting for the a fully stable release - it will be great!
    Greets!
    Boris
  • »24.03.09 - 20:02
