Pagestream selecting text
    amiga4001
    Posts: 453 from 2006/11/16
    I am unable to select text in pagestream.
    For example to change it's size after typing.
    Is this a bug or has it a conflict somehow.
    For the rest it seems to work ok including printing.
  • »20.01.07 - 19:12
    Posts: 126 from 2003/2/17
    intuition bug, w8 for next mos release..:-(
  • »21.01.07 - 06:16
    amiga4001
    That's a downer but program is still very usable.
  • »21.01.07 - 06:18
  • tom
    tom
    Posts: 148 from 2003/7/22
    I'm using Pagestream from the beginning of Morphos and there was a problem in the start. If using 24bit screenresolution I couldn't see the selected text. After changing to 15 bit the problem was gone. Now I'm using a Radeon 9250 and now it's possible to use also 24 Bit.
    That's untill now the only problem I ever met (and i use Pagestream daily!)
    regards Tom
  • »21.01.07 - 17:40
    amiga4001
    Yes indeed when switching to 16bit screen it works.
    Well guess it already worked but couldn't see it.
    Are all radeon 9250 ok for pegasos?
    Or only some brands?
    I got a 9200SE now and works ok but there are plenty 9250's for a bargain to have so..
  • »22.01.07 - 04:23
