X1000
    Posts: 12058 from 2003/5/22
    > G4 class performance
    Can you give any meaningful benchmark comparison between e6500 and e600 cores? At least Dhrystone benchmark results in 43% better per-clock performance of e6500 (single-thread) vs. e600. This would need a 2.4 (2.2) GHz e600 to match a 1.67 (1.53) GHz e6500 (single-thread).
  • »05.06.14 - 14:34
    > SAM 460, which unless something changed I am not aware of, it is a computer
    > still in production
    It should have re-entered production some weeks ago, according to information from ACube:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=8931&start=143
  • »05.06.14 - 14:48
    > I would rather see a 32 bit Amiga compatible PPC Mac plus a NG MorphOS 64 bit
    > non-PPC machine worked on simultaneously. With the G5 you could even have
    > both on the same machine as a stop gap measure.
    A non-PPC OS on the G5? ;-)
    > we could maybe [...] use the money to reward people who make big contribution
    > for MorphOS in general?
    This sounds like the bounties that happen once in a while.
  • »05.06.14 - 15:07
    > off the self x64 is out of the question, so until custom x86 becomes cheaper
    > than custom PPC, let's stay with the PPC
    Why must it be custom x86(-64) instead of off-the-shelf x86(-64)? And if we're talking about custom boards, then why shouldn't x86(-64) be cheaper than PPC considering that x86(-64) chips usually have better price-performance ratio and all other costs are similar?
  • »05.06.14 - 15:25
    KimmoK
    Posts: 102 from 2003/5/19
    To build support for the HW.
    Normal off the self x86 motherboards have production lifecycle of three months or so. (it takes months to reverse engineer the support for a HW componet when we can not get much documentation)
    Industrial x86 boards have longer availability with higher price etc...
    Only recently there has been x86 SoC chips with PCIex4 etc, so the board design would most likely require more components.
    And from what I have found, usable x86 is not any cheaper than a usable PPC.
    (but I'm not an expert, just learning etc...)
    Performance wise, yes, in that way price-performance ratio is better for x86.
    (I believe a common 1.33Ghz x64 SoC has twice the performance of similarly clocked e5500 PPC, +SIMD +GPGPU)
    For me, it is more like what we need than trying to compete with mainstream with CPU power.
    Knowing how much better MOS runs on 1Ghz G4 vs Linux on younger 1.8Ghz AMD Sempron machine, some 1.4Ghz PPC would be ideal for LOW END NG miggy.
    ((T10xx consuming some 5W, I imagine it could be usable also in some (semi)mobile device))
    (I personally prefer big endian + PowerPC as long as most of our SW is native on that etc...)
    [ Edited by KimmoK 06.06.2014 - 11:45 ]
    :-x :-P 8-)
  • »06.06.14 - 11:36
    Yasu
    Posts: 1724 from 2012/3/22
    @Andreas_Wolf
    G5 is 64 bit, right? So before a possible move we could base the Next Gen MorphOS on that. Or maybe PPC by then becomes a resonable candidate again. Then having a working 64 bit MorphOS with all the goodies could make the job easier. Maybe.
    I just want a modern AmigaOS. MorphOS is by far the closest. It doesn't have to be the fastest or the cheapest, but it needs to look forward and not back. If I know there is a future (which has been confirmed, but no details revealed nor signs that it's being worked on atm) I don't mind waiting.
    My MorphOS blog
  • »06.06.14 - 11:52
    > [...] Industrial x86 boards have longer availability with higher price etc...
    It's still cheaper to use industrial off-the-shelf x86 boards than custom x86 boards.
    >> than PPC
    Why more components? Intel offers multicore x86(-64) SoCs with 8 PCIe lanes, USB, SATA and GbE for 60 USD. That's about the same feature set as PPC SoCs (ignoring PPC's DIU, which isn't suited for real desktop use anyway). And Intel also offers multicore x86(-64) SoCs with 4 PCIe lanes, USB, SATA and 3D GPU for mere 30 USD. Here you'd only need a cheap separate Ethernet chip. Audio would be needed separately with all those solutions, including PPC SoCs.
    From AMD you can get multicore x86(-64) SoCs with 8 PCIe lanes, USB, SATA, GbE (using one PCIe lane), HD audio and 3D GPU for 70 USD. That's really all-in-one.
    Well, 30 USD for an Intel x86 SoC with 3D GPU (only lacking Ethernet compared to PPC) or 70 USD for an AMD x86 SoC with really everything needed. I think this would come out cheaper than PPC.
  • »06.06.14 - 20:17
    Yes, and PPC :-)
    Yes, a 64-bit SMP OS would be doable on the G5, of course.
  • »06.06.14 - 22:28
    *double post*
  • »06.06.14 - 22:28
    > Is G4 64 bit?
    No, G4 is 32-bit (with a 36-bit address bus).
  • »06.06.14 - 23:34
    Yasu
    @Andreas_Wolf
    I thought so. So what do you mean by:
    Yes, and PPC :-)
    My MorphOS blog
  • »07.06.14 - 12:27
    > Quote:
    Yes, and PPC :-)
    I mean that the G5 is not only a 64-bit CPU but also a PPC CPU :-)
  • »07.06.14 - 19:44
    64-bit and PPC, just like the PA6T, the P5020, the P5040, and the T1042.
    So we have what we need without an ISA change.
  • »07.06.14 - 19:53
    Yasu
    @Andreas_Wolf
    Ah, we are speaking of two different things then. But I understand the misunderstanding. I meant that IF MorphOS will be shifting to another CPU, then you can first work on a 64 bit version on the G5 since it's already supported.
    My MorphOS blog
  • »07.06.14 - 22:23
    Addendum:
    >> "IIRC, Ben Hermanns is no longer a partner of A-Eon, since they
    >> reformed in the UK and closed the Belgium based company."
    >> http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=35093&forum=32#651254
    > And indeed, A-Eon's October 1st [2011] press release has been the last one where
    > the company calls itself a CVBA. Starting with the one from October 12th [2011],
    > all 8 subsequent press releases have missed the "CVBA" bit. So [...] Ben
    > Hermans' involvement in A-Eon ceased somewhen between October 1st and
    > October 12th [2011]
    AmigaKit now claims this happened already one year earlier:
    "Later on in late 2010, our role changed and we had to help get the project back on track."
    http://www.amigakit.com/catalog/news.php?news_id=181#newsid181
    http://www.amiga.org/forums/showpost.php?p=767411
    http://amigaworld.net/modules/news/article.php?storyid=7129
  • »23.06.14 - 22:41
    number6
    Posts: 473 from 2008/8/10
    @Andreas_Wolf
    somewhat stronger statement from March of this year
    It's worth noting that he's stating for the record that Trevor was only a silent partner and not managing the company.
    It's also worth noting that he's stating neither Amigakit nor Trevor were to blame due their roles at the time.
    #6
    [ Edited by number6 28.06.2014 - 09:40 ]
  • »28.06.14 - 14:38
    number6
    @Andreas_Wolf
    Understood. Wording makes this difficult. You could argue the following offers yet another date:
    same thread as referred above
    I have read with interest the comments in the past year since I have been involved in the A-EON project:
    That can mean he's been involved only in the last year OR he's only read comments with interest in the past year.
    "involved" is a vague term regardless.
    I don't think the specific info you are looking for is stated concisely anywhere.
    #6
  • »28.06.14 - 19:24
    boot_wb
    Posts: 874 from 2007/4/9
    >> AmigaKit now claims this happened already one year earlier: [...]
    Unfortunately, nothing there about the late 2010 vs. late 2011 discrepancy I was getting at.
    It's possible that Trevor brought Amigakit onboard in a consulting role late 2010 to help get the X1000 development back on track under A-Eon CVBA, with the change to A-Eon Technology Ltd (and hence change in ownership & management) taking place in the October 2011 period.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »28.06.14 - 19:56
    > You could argue the following offers yet another date: [...]
    > Quote:
    I take this to be a mere typo, missing plural 's'. '2010' instead of '2011' could be a typo as well, of course.
  • »29.06.14 - 15:47
    Yes, that's possible indeed.
  • »29.06.14 - 16:35
    Posts: 236 from 2003/7/28
    Jim wrote:
    I think that Rajinder refers to Dickinson sending the MorphOS Team a bare Rev2 Nemo board.
    Man, I'm surprised they got that. But how were they supposed to assemble it and where do you get a PA6T from?
    I highly doubt he sent them a _bare_ board. I'm sure it's fully populated with all the necessary components (and CPU). By "bare" I think he meant they were sent a functional motherboard only, not a complete system with case, drives, etc.
  • »30.06.14 - 13:08
    >>> Rev2 Nemo board.
    > By "bare" I think he meant [...] a functional motherboard only, not a complete system
    Yes, I meant exactly that, as clarified by me 12 postings and 5 hours after the statement:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7183&forum=3&start=19
  • »30.06.14 - 17:57
    >>> Rev2 Nemo board.
    I didn't bother to read the entire thread because I knew you would point out any oversight ;)
  • »30.06.14 - 18:05
