Discussion of the Tabor / A1222 mainboard
    Kronos wrote:
    Neither Tabor nor X5000 have Altivec.
    Yes, an issue with e5500 cored cpus, but not as big a deal as the e500v2's fpu.
  • »08.10.16 - 22:41
    Posts: 12077 from 2003/5/22
    > firmware updates are extra
    That was ACube, not A-Eon.
    > Efika level performance in real life.
    This would depend on the amount of floating point code in one's particular real life. Tabor's integer performance per core should be about 4 times Efika 5200B's.
  • »08.10.16 - 23:21
    redrumloa
    Posts: 1424 from 2003/4/13
    Isn't Acube a partner with A-Eonkit for the Tabor?
    [ Edited by redrumloa 09.10.2016 - 13:17 ]
  • »09.10.16 - 00:28
    Yes, they are. That still doesn't mean A-Eon will adopt ACube's firmware update policy, does it?
  • »09.10.16 - 08:13
    > The releasedate should now be importent, to keep some momentum....
    It's gotten a little bit nearer: https://www.youtube.com/watch?v=fMSvxQIfq2w
    Well, they always said they would focus on this once the X5000 was ready for delivery, and that is close, so...
    It will be interesting to see how the whole issue of the P1022's spe fpu plays out.
    In software specifically compiled for the A1222, no problem, BUT...
  • »24.11.16 - 15:17
    A year later and Daniel "Daytona675x" Müßener posts "a good demonstration of why you must not mix FPU and SPE code as soon as floating point values are involved" (i.e. mixing as in SPE-compiled executable calls FPU-compiled library or vice versa):
    https://www.facebook.com/daniel.mussener/posts/2086799091346527
  • »03.01.18 - 12:39
    Posts: 2720 from 2003/2/24
    Daniel Müßener: "Note: VoxelNoid is barely playable (if shadowing is turned off it's okay) on the Tabor as of now, the Warp3D SI driver is simply doing to much stuff internally that involves FPU instructions and therefore constantly and frequently triggers the emulation.
    My tests revealed that this is apparently due to FPU-register-based memcpy (when drawing vertex data and when uploading textures) and RGBA-color-format-conversions from packed uint32 to unpacked float[4] done using FPU code.
    Hans has been informed, hopefully his time allows it to make the respective code more Tabor-friendly soon "
    "Barely playable", and we are not exactly talking about Star Wars Battlefront 2.
    And so it begins, the parallel development of both "normal" code and "franken-code", just to satisfy a small group of customers with a one-time-deal HW that will never see the sun again.
    It makes so much sense that only Amiga makes it possible!
    [ Edited by takemehomegrandma 03.01.2018 - 13:12 ]
  • »03.01.18 - 13:04
    Posts: 18 from 2017/10/7
    VoxelNoid works fluently at 720p with all settings to max on my mdd g4 1.25 soooo...
  • »03.01.18 - 14:39
    Posts: 1246 from 2004/2/8
    Oh yeah? But does it get anywhere near the spectacular count of 1075037508 FPS? LOL...
    The issue described by Daytona will make porting for Tabor oh-so-more-funny for the devs.
  • »03.01.18 - 16:01
    redrumloa
    ppcamiga1 wrote:
    http://www.os4welt.de/viewtopic.php?f=4&t=1670&sid=e2c6fbaecf723b05ca59e3531417292b
    So, I was right about apes throwing shit on a-eon and powerpc technology in general.
    Some people simply don't like bitter truth.
    btw netbsd has port for e500v2 for three yrs, and users of this port also report
    that trapping fpu instructions on e500v2 is not a problem, and has no impact on performance.
    This comment has not aged well.
  • »03.01.18 - 23:22
    redrumloa
    redrumloa wrote:
    Cego wrote:
    dude, i think some of you dont get the point.
    the situation is not about "slow cpu" vs "faster cpu"
    its rather "slow cpu" vs. "nothing at all". so be grateful that at least somethings still coming. we're not a huge community and its not like we can choose everything we dream about. What have you done for the community? maybe thats the question you should ask yourself.
    Did I just walk into the Twilight Zone? Why exactly should a MorphOS user be grateful A-Eonkit will be selling a Raspberry Pi class motherboard for an exorbitant amount of money? A board that the MorphOS Team have rightfully stated would be a waste of time supporting?
    Also, why do you even pose a question about "done for the community"? The only thing end users need to do is vote with their dollars. A-Eonkit are running a commercial business, not a nonprofit charity.
    This board won't be for sale with a working OS4.1 port until at least 2018. Do you really expect people to pretend like a ~500Euro rpi level board in 2018 will be a good idea?
    I can see the future it seems.
  • »03.01.18 - 23:27
    Posts: 80 from 2017/9/10
    sorry but i have to make a quick reply
    tabor is not like a pi in performances just because a pi3 overkill it. the only good point of tabor is the pcie slot that the pi dont have.
    just for, this is the imx6 board from freescale with arm cpu ... dont think you will have this performances on tabor
    https://www.youtube.com/watch?v=N3QY74keH_E
    ogre demo https://www.youtube.com/watch?v=foOm9OQ9IE8
    about A-Cube and A-eon for the tabor ... are you sure than a-cube made the tabor or do something about?
    [ Edited by tlosmx 04.01.2018 - 09:34 ]
  • »04.01.18 - 10:24
    Posts: 2239 from 2003/2/24
    A day after the 31st December 2018 it will be the year 2019!!
    I can see the future too !!!!!
    Now tell me this weeks Lotto numbers and we might be onto something ;)
  • »04.01.18 - 11:33
    There are various Raspberry Pi models with CPUs ranging from 700 MHz single-core ARMv6 to 1.2 GHz quad-core ARMv8, where the latter should be over twice as fast as the former on per-core basis alone. So talking about "Raspberry Pi class" or similar without specifying the model doesn't make sense anyway.
    Tabor is definitely way faster than all Raspberry Pi 1 models (700 MHz ARMv6). Regarding quad-core Raspberry Pi 2 (900 MHz, ARMv7 initially, ARMv8 in later revisions), Tabor should be faster on per-core base but is slower in SMP. Comparing against quad-core Raspberry Pi 3 (1.2 GHz ARMv8), one's as good/bad as the other on a per-core base, so Tabor obviously loses in SMP.
    No, this is a board from FEDEVEL/VOIPAC with an ARM-based i.MX6 CPU from NXP :-)
    The i.MX6 used on the board is a quad-core, yes. Comparing the 1.2 GHz Cortex-A9 and the 1.2 GHz e500v2 on a per-core base, one's as good/bad as the other.
    As is well known, the Tabor has been designed by Varisys. Regarding the ACube connection:
    "Working in cooperation with ACube srl, a beta test programme is about to commence"
    http://www.a-eon.com/news/News_Release_A1222.pdf
    ...and there was this in 2013:
    http://www.a-eon.com/news/14-12-2013.html
    http://www.acube-systems.biz/news.php?id=127
    ...and this in 2015:
    http://www.a-eon.com/PDF/News_Release_Summit.pdf
    http://www.acube-systems.biz/news.php?id=135
  • »04.01.18 - 13:31
    Tabor is all Varisys and acube dint nothing . i was thinking the same about tabor that there was acube hands on it ... but no they at the end didnt nothing on that crappy.
    about freescale or nxp ... we are speak now about the same company ;-)
    about pi3 ... blender using the 4 cores on the pi is faster in blender bench compared the x5000-20 that use two cores . tested by me... pratically if you render something you will have same time on a 35 euro computer compared a 2300 euro computer :P
    darkplace on SPE Linux on Radeonhd = 70 fps on Tabor if some one have better result because what i have is old pls post here it .Thanks
    [ Edited by tlosmx 04.01.2018 - 18:21 ]
  • »04.01.18 - 19:14
    Actually, I was under the impression that Acube was to develop the firmware for the platform.
  • »04.01.18 - 19:17
    I was thinking the same...but ..
    [ Edited by tlosmx 04.01.2018 - 18:25 ]
  • »04.01.18 - 19:24
    Its not really an issue for me, as Tabor holds no appeal for me.
    But Acube would be the natural company for the T2081 laptop project to go to for firmware (after all, they've already been tapped for design work).
  • »04.01.18 - 19:30
    i can say sure yes about openlaptop and acube :)
    i know many people involved in this project and for sure acube is involved
    [ Edited by tlosmx 04.01.2018 - 18:46 ]
  • »04.01.18 - 19:45
  • rob
    rob
    Posts: 139 from 2008/7/22
    Three Tower57 port Tabor fun facts:
    - the latest SPE build reaches up to 80 fps. This simply demolishs the sam460ex, factor 2.
    - when running the latest FPU (!) build on the Tabor it reaches up to 40 fps (!) (old OS version, first fpu-emu).
    - when running the latest FPU build on the sam460ex it reaches up to 40 fps.
    So the Tabor is even en par with the sam460 if running the version which is incompatible with its FPU :)
    And before you say sth. a la "then you optimized away most fpu instructions"...
    Wrong, think, man, think - and don't forget that the SPE build runs twice as fast... Yeah, the SPE is a pretty fast FPU unit indeed, but looking at the emu-speed that whole A1222 delivers (y)
    Still anybody out there making up stories about the A1222's performance compared to the SAMs or about the power of the SPE? LOL
    Yes, I know: VoxelNoid and VoxelBird on Tabor are nice, but I suppose most of you were curious about Wings ;)
    And here it is:
    The current Wings Remastered Demo (no, it's not finished yet) build, compiled for SPE, running on the Tabor.
    As being said before the Warp3D driver still contains FPU code (which ironically is actually inside to improve performance on systems with standard FPU) which is the cause for severe performance penalties because it constantly triggers the exception-based FPU emulation.
    But even then: as you can see everything but strafing and dogfight run smooth as butter, and even those two mission types are still playable! The Tabor is certainly a pretty powerful beast if unleashed!
    Now imagine if that driver was modified to not trigger the emulation anymore...
    As always with the Tabor videos here: the sound-driver is not done yet, therefore nothing but silence for now, unfortunately.
    So it's not all doom and gloom after all.
    [ Edited by rob 04.01.2018 - 20:19 ]
  • »04.01.18 - 21:18
    My point was that the board you mentioned was not from this company, just the SoC is.
    > the x5000-20 that use two cores . [...] if you render something you will have same time
    So the X5000/20 is about twice as fast per core as the Raspberry Pi 3. And as the X5000/20 is about twice as fast as Tabor, Tabor is about as fast per core as the Raspberry Pi 3. Just as I said :-)
  • »05.01.18 - 01:19
    The comment you replied to was about the compatibility problems developers will have to cope with, not about speed (non-)issues. What does speed help when it's not working right, except that it'll crash and burn or show nonsense faster?
  • »05.01.18 - 01:31
  • rob
    rob
    Only if they are using SPE code. If you can get the same performance from Tabor as the Sam460 with standard FPU code then you may not have a need for special binaries.
  • »05.01.18 - 08:03
