cpan with perl
    weiseb
    Posts: 215 from 2003/3/29
    Is it possible to install a perl modul on morphos?
    If I use cpan it fails because it tries to fork
  • »25.11.25 - 06:22
    Posts: 3323 from 2003/3/5
    You'd have to modify it not to use fork, would be my guess.
  • »25.11.25 - 11:32
    Piru
    Posts: 619 from 2003/2/24
    The obvious fork usage I can see is related to testing.
    You can sidestep this by using "notest install". This is not great, but at least I managed to install things this way.
  • »25.11.25 - 15:30
    weiseb
    Thank you, skipping the tests worked for me as well.
  • »25.11.25 - 18:09
