Posts: 545 from 2015/6/18
Quote:Elowan schrieb:
So I did re-size (move) main debian partition, then added a new one, left 128GB space (unallocated) and created a 60MB "Boot" HFS and a 4,x GB (unformatted) partitions (see image)
click here ->
qD5XoRm.jpgMy debian install is kind of dead DAMM IT !!!!
Says something like "/dev/sda7 unexpected inconsistency" and that sda7 need fsck manually...
what sda7 ???? I got sda 1 to 6 - but no sda7, see image (!)
What to do next?
Mkay. Not so good... Maybe if partitions are created not at the end of the disk it can screw the numbering scheme? But I don't know for sure. But that's not a big problem, you can fix this as I did that one time before.
Boot with your Linux Live DVD, open a terminal, go root with
sudo su. Type
blkid to check your partiton layout. Maybe your partition numbers are shifted now and you are seeing some /dev/sdaX with PARTLABEL="Extra" now. The important thing is to know which partition is your Debian root and which one is the yaboot partition.
I had a quick look on your yaboot.conf. Your root partition was the one with "UUID=926469b7-94af-4d34-8622-a13c249c59be". This should also be the case now. Now it's the time to edit your yaboot.conf on disk. Mount your root with
mount /dev/sdaX /mnt/ where
X has to be the correct partition number. Then edit your yaboot.conf with
pluma /mnt/etc/yaboot.conf & or whatever the text editor is on your Linux Live DVD. I use Ubuntu MATE, so it's pluma.
Search for the
root= line. In your case this is
root="UUID=926469b7-94af-4d34-8622-a13c249c59be" which should still match the output from
blkid. If not, change it accordingly to the correct UUID value of your root shown in blkid.
Next, check the
partition= line above. The number must match the partition number of your root, e.g. if your root is /dev/sda8 then you should write
partition=8 here.
Last thing left is to check the
boot= line. This is not a Linux device path but an OpenFirmware device path. It's about the HFS-partition where Linux installed yaboot. On a system with only one harddisc only the partition number at the end matters, e.g. boot="blablabla
-part3". The part number here must match the output of blkid too. If your HFS-yaboot partition is /dev/sda3 in Linux terms, then
boot="blablabla-part3",
Ok, you are done editing yaboot.conf now. It's time to write the changes to disk with
ybin -v -C /mnt/etc/yaboot.conf. Check the output of ybin if it wrote to the correct partitions and 'blessed' them. If everything was correct your Debian will boot again!
So, now you are an expert too.
Here comes the easy part to add MorphOS as a 2nd boot option:
Edit your yaboot.conf again, adding
macos=/dev/sdaX with
X being the partition number of your HFS-MorphOS boot-partition. If you want to default to booting MorphOS add another line
defaultos=macos. Write the changes to disk with
ybin -v again (no need for the -C option here).
That's basically all the magic involved! For more detailed information you can type
man yaboot.conf in your shell.
