Problem installing 3.20 on X5000
    Posts: 2 from 2026/8/21
    Hello Folks, I am new here.
    I would like to install MorphOS on an X5000 but I am stuck.
    A couple of years back I had a USB or a DVD and used MorphOS now and then, but I never managed to install it to the internal storage. That's why I never bought a license.
    Since then I did not change anything hardware wise.
    Yesterday I downloaded version 3.20 and successfully wrote the image on a USB stic using "rawwrite", however I can not boot the system. These lines appear on the screen:
    MirphOS boot loader version 1.17
    Select a boot partition:
    * 1. HDIMG0: (boot priority 15)
    2. DH0: (boot priority 0)
    3. DH1: (boot priority -1)
    Timeout, booting from HDIMG0:
    Trying to load "bootcyrusplus.img" from "HDIMG0:"....
    Loaded "bootcyrusplus.img" from "HDIMG0:", booting...
    And then it stops there.
    I can reset the system using CTRL-Amiga-Amiga, so apparently the system does not freeze.
    I re-wrote the image to the USB using "dd" this time, but the results are the same.
    Any idea what I am doing wrong?
    Unfortunately I can not burn a DVD in order to try out the liveCD.
    Any help appreciated!
    Murphy.
  • »21.08.26 - 08:34
    Posts: 2571 from 2003/2/24
    Might help if you would specify the exact config, which GPU what kinda drives and so on.
    Or just try another USB stick which might make a difference as it seems to fail at a point where MorphOS takes over from the bootloader.
  • »21.08.26 - 08:46
    Posts: 3334 from 2003/3/5
    If you have 2 Radeon cards, the other one may be picked up by MorphOS now - and if that one is connected via DP it wouldn't work. That port isn't supported at all.
  • »21.08.26 - 10:28
    Primax
    Posts: 220 from 2021/7/2
    @Murphy
    We have already discussed that problem on discord some days ago.
    I was stuck in the same place. This is not about the USB stick, it is a big which is Frank already aware of it.
    And I hope he is spending nights and days to fix it... ;)
    To make it short: we X5000 users have to wait for the fix.
  • »22.08.26 - 04:36
    In that case he might just download 3.19 and try that.
    And wait for 3.21.......
  • »22.08.26 - 04:57
    Primax
    3.19 definitely works!
    But then he cannot use the latest Iris and Wayfarer versions since they require MorphOS 3.20!
  • »22.08.26 - 05:03
    @Primax
    All right, thanks.
    @Kronos
    It's a Fujitsu 00Y21L hard drive and a ATI 9000 Pro graphics card. I took that one out and put in a HIS R7 250X (I know the simple 250, without X are not suppurted) but the system didn't boot with any of the cards.
    @jcaps
    Only one card in the system at a time. One connected via DVI the other one through HDMI to the monitor.
    The old morphos version worked with the exact same hardware. I very stupidly used the same USB stick because I didn't have another one available. I deleted the working MorphOS version (I think it was 3.14 not sure) and wrote the new one to the same stick.
    Thanks for all the replies
  • »22.08.26 - 05:08
    Posts: 13 from 2021/3/11
    Murphy.
    I solved the problem following the instructions provided at the following link.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=14223&forum=11
  • »22.08.26 - 16:47
    Primax
    @amigait10
    Eh? What is solved there? Nothing. It is the same problem and he stucks there.
  • »24.08.26 - 02:20
    pampers
    Posts: 1071 from 2009/2/26
    Primax wrote:
    @amigait10
    No, that workaround is working for me.
    MorphOS 3.x
  • »24.08.26 - 11:42
    It worked for me too, but to install MorphOS I had to remove the SD card where I installed OS4.1 and plug in a SATA DVD and boot from the DVD.
    After installing MorphOS, I removed the DVD and re-installed the SD card with OS4.1.
    My configuration is as follows:
    X5000-20
    PCI-e 16x Radeon RX 570 for OS4.1
    PCI-e 4x Radeon Radeon X1950 Pro for MorphOS
    SATA Port 0 SD OS4.1
    SATA Port 1 SD MorphOS
    If I remember correctly, reversing the SD card order in the SATA ports didn't work.
    Sorry for my English, but I used a translator.
  • »24.08.26 - 17:08
    Primax
    Hm, obviously I am blind... :(
    Apart from the fact, that I did not have a DVD drive, I cannot see any workaround in the linked thread...?!
    Anyway. I hope, Frank will find a solution soon for the USB way.
  • »25.08.26 - 07:56
    pampers
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=14223&post_id=164386&viewmode=flat&sortorder=0&showonepost=1 - here Bruh
    You need to enable debug as it slows down the initiation and then on some machines it helps to get it booted.
    MorphOS 3.x
  • »25.08.26 - 14:27
    Posts: 611 from 2003/4/11
    Yea, it is an unfortunate regression in the MorphOS 3.20 Release that crept into the X50x0 SATA driver.
    We are currently testing some modification that is supposed to remidy the issue.
  • »27.08.26 - 20:34
    Primax
    Thanks. But unfirtunately does not change anything here with my X5000.
    Have to wait for Frank's solution...
  • »30.08.26 - 08:22
    Try disconnecting the HD where you installed OS 4.1 (that was the reason why it wouldn't boot).
    Then try booting from the USB stick.
  • »30.08.26 - 12:49
    Brumiga
    Posts: 277 from 2004/4/3
    I see that you Primax have a x5000/20. And you Murphy have you a5000/20 or a x5000/40 ? Which have you both ? The latest one from BigFoot or an older one from A-Eon ? To know it, stop after the animation and enter in terminal/command line mode, then type version. If you have the latest one from BigFoot you should obtain on 3 lines the following text.
    U-Boot molsen-2018-10-05 (Oct 05 2018 17:02:05)
    ppc-elf-gcc (GCC) 4.7.3
    GNU ld (GNU Binutils) 2.25
    Here are aslo some addtional options about u-boot.
    amigabootmenu_animate default 1:
    Set to 0 to disable the boot animation. Set to 1 to enable the animation.
    amigabootmenu_animcycles default 10:
    Specifies how many times the animation should be played before the default boot selection is booted. Only has an effect if amigabootmenu_animate is set to 1.
    amigabootmenu_timeout default 0:
    If set to a non-zero value, it specifies how many seconds should elapse before the deafult boot selection is booted. This mechanism overrides amigabootmenu_animcycles, so if both are set, this one takes preference.
    amigabootmenu_animcycles=1
    amigaboot_quiet=y
    Hoping that may help you a few.
    Edit : the 2 last lines are the settings I did.
    Brumiga
    [ Edité par Brumiga 30.08.2026 - 19:38 ]
  • »30.08.26 - 14:37
    Primax
    Thanks for all the hints!!!
    Unfortunately, it does not change anything. Disconnecting the OS4 drive makes no difference.
    Frank, please find a solution!! :)
  • »02.09.26 - 18:29
