Posts: 2220 from 2003/2/24
Check your "Functions" settings in Snoopium. Maybe you have "Only show fails" enabled?
Anyway it's normal to get some fails when a program tries to open its resources from different locations until it succceeds. The most important thing is that the last try will show OK even though there would be fails before it.
