Keyfile Fails To Register
    Posts: 13 from 2025/9/2
    Hi! New user here.
    I just received my keyfile, and I put it in the Devs drawer as instructed. But Morphos still is still in demo mode (after reboot).
    Where have I gone wrong?
    Thanks!
  • »09.09.25 - 05:15
    Posts: 1390 from 2010/1/6
    Named it morphos.key? Then it should work.
    Only on EFIKA is a known issue, because there can change the MAC under special circumstances.
    What is your computer? Mac? Put ist on the same machine, where you have done registration?
  • »09.09.25 - 05:31
    Posts: 2220 from 2003/2/24
    Do you have it named as "morphos.key" and not "morphos.key.bin" or something like that? Doing "list devs:morphos.key" in the shell shows the file? Does it have the R protection bit set? What hardware is it?
  • »09.09.25 - 05:34
    Yeah, it was a naming issue. I just copied it over the way I got it.
    Works great now.
    Thanks!
  • »09.09.25 - 05:45
