Unable to Install from USB Stick
    SP73105
    Posts: 4 from 2025/6/23
    I have downloaded the MorphOS 3.10 CD image and copied it to a FAT32 formatted USB stick in Mac OS.
    Per the instructions I also copied the Boot.img file from the PPC32 directory as I am trying to install MorphOS on an iBook G4.
    The install proceeds after typing in the correct command, "boot ud:,\boot.img bi umsd0:morphos.iso” in OpenFirmware but hangs after the “DO-Quiesce finished” message. I hear the hard drive and/or fan run briefly.
    I have tried 2x with two different USB sticks - same result.
    The internal hard drive in the Powerbook has two partitions - - not sure if that makes a difference.
    Computer Specs:
    Machine Model: Power Book6,7
    CPU Type: PowerPC G4 (1.5)
    Number Of CPUs: 1
    CPU Speed: 1.33ghz
    [ Edited by SP73105 23.06.2025 - 05:51 ]
  • »23.06.25 - 10:42
    Posts: 12557 from 2003/5/22
    Why not 3.19?
    > and copied it to a FAT32 formatted USB stick in Mac OS. [...]
    > The install [...] hangs after the “DO-Quiesce finished” message.
    Are you sure you really copied the ISO image itself and not just its contents?
  • »23.06.25 - 13:06
    SP73105
    Apologies. It is indeed 3.19. That was a typo.
    Here is a screenshot of the USB stick and it’s contents:
    https://ibb.co/h1DtsyvS
    ImageBB
    [ Edited by SP73105 23.06.2025 - 08:52 ]
  • »23.06.25 - 13:52
    SP73105
    I resolved this. In my multiple attempts my last usb format was in Mac OS Extended NOT FAT32.
  • »23.06.25 - 14:07
