Powerbook G4 A1138 - Dualboot with MacOSX10.4 and MorphOS 3.19
  • xix
    Posts: 14 from 2021/5/15
    Hello Community,
    my machine is Powerbook G4 A1138 with SSD. Previously I've used a registered MOS 3.18 but wanted to have a multiboot System with MOS 3.19 and MacOS10.4. I've followed (https://dreamolers.binaryriot.org/dualboot.pdf) and installed first MacOS10.4 and then MOS 3.19. Now if I try to boot MOS 3.19 I am getting a grey screen. I've done the instalation of MOS twice but with the same result, somehow I can't find the problem, maybe you guys have a hint for me how to diagnose my problem.
    [img align='left']https://drive.google.com/file/d/1gFDJKoz47ft-cppC6jVgiIabeiWnYbRr/view?usp=sharing[/img]
    [img align='left']https://drive.google.com/file/d/1gEHsfItdpztZJxeGRENZ75FZIYBJ8yvD/view?usp=drive_link[/img]
    [img align='left']https://drive.google.com/file/d/1gG-PS07J4-RFq1FwEDw9qluFUaGaMvtY/view?usp=drive_link[/img]
    [img align='left']https://drive.google.com/file/d/1gEGKWQmoCfp0dAX1DRZZ5768L3WtfVr1/view?usp=drive_link[/img]
  • »08.04.25 - 04:53
    Posts: 1360 from 2004/2/8
    Enter Open Firmware and type:
    printenv boot-device
    what does it say?
  • »08.04.25 - 05:05
  • xix
    boot-device pci2/ata-6@D/@0:6,\\tbxi hd:,\\tbxi
    Default boot goes to macosx, I just tried to boot using alt-bootmenu.
  • »08.04.25 - 05:11
    What happens when you change the boot-device like:
    setenv boot-device hd:,\\tbxi
    [ Edited by koszer 08.04.2025 - 09:12 ]
  • »08.04.25 - 05:12
  • xix
    Now of course the mos partition is selected as first to boot, but the result is the same.
    I've tried to boot with hand w/o bootmenu.
  • »08.04.25 - 05:23
    That's strange indeed. And the Live CD (or USB boot) seems to work just fine?
  • »08.04.25 - 05:27
  • xix
    yep booting from cd is ok. Hmmm I've also used MacOS10.4 Shuriken, not sure if this is a problem somehow.
  • »08.04.25 - 05:30
  • xix
    I've installed just MOS 3.19 with automatic partiotioning, and checked for differences in HDConfig, I can see that the automatically generated partitions have the flag enabled 'In Use (A/UX)', might this be the problem? what does the flag do?
  • »08.04.25 - 07:08
  • xix
    So Boot partition is in HFS and initializes boot from OF, how does the Boot partition know, where MorphOS is located, to be able to select to proper partition?
  • »09.04.25 - 04:03
  • xix
    The Multiboot-Guide says:
    "Note: do NOT remove the 128MB padding partitions. Mac OSX expects them to be
    there!"
    So: I removed the 128MB padding parition between DH0 (Boot) and DH1 (System) :D
    The Boot partition is set a 1st to Boot (in OF) - default one
    Now I can:
    - Boot into MorphOS w/o using Bootmenu (alt pressed) - default one
    - Boot into MacOSX using Bootmenu
    - If there is MorphOS-CD inserted MorphOS will boot from CD automatically.
    Now I can't:
    - Boot into MorphOS using Bootmenu. The screen is going gray and stays there.
    Is this a normal thing? Did I miss some docs?
    [ Edited by xix 09.04.2025 - 09:15 ]
  • »09.04.25 - 05:14
    Posts: 12557 from 2003/5/22
    "Without arguments MorphOS boots a device that is bootable and has the highest boot priority set. Note that this only applies to partitions that contain a MorphOS compatible bootable filesystem. If a MorphOS installation CD is inserted, it usually has a higher priority than bootable partitions on the HD. The HDConfig tool can be used to set partitions bootable and alter their boot priorities […]."
    https://library.morph.zone/Open_Firmware#Boot_Arguments
  • »09.04.25 - 05:16
  • xix
    DH1 has boot priority set to 0, and is the only SFS partition.
    Does my system now behaves normally, or why did I had to remove the 128MB padding partition?
    I mean I am happy, that it works, I am just wondering, if this is a normal thing?
  • »09.04.25 - 05:26
