How to destroy Datos partition and create 3 new partitions?
    Posts: 123 from 2022/7/1
    Hello,
    I want to destroy 1 partition and create 3 new with the space regarded
    How can I do it?
    My Datos partition is now write protected and I am stack in this issue.
    Any help will be highly apreciated.
    Thanks
  • »07.02.25 - 15:27
    Posts: 3276 from 2003/3/5
    HDConfig won't care if the partition is write protected. Simply delete it and create new ones in its place.
    If you want to be double-safe, delete the partition first, save changes and reboot.
  • »07.02.25 - 16:13
    Yeah but I don't want to create ones,I only want one for the Datos partition.
    My Datos partition is still as write protected.
    How can I tick it as read&write if this is correct?
    Maybe with SFSDoctor?
  • »08.02.25 - 16:14
    Perhaps you've managed to lock it?
    Try 'Lock Datas: off' in a shell
  • »08.02.25 - 22:02
    OK now I have no problem with "Datos"
    To destroy it I created 3 new partitions with the tool HDConfig and surpringsily apeared the Datos partition only in Ambient.
    Later clicked with the right mouse button on Information an is shown as activated.
    Happy now to have this partition again
  • »09.02.25 - 14:37
