Registration Issues
    Posts: 2 from 2024/10/21
    Hi, my system is up and running and connected to the internet - but cannot seem to connect to the morphOS servers to register it - can you advise please?
    Cheers
    Mark
  • »26.10.24 - 10:28
    NewSense
    Posts: 1578 from 2012/11/9
    Hi Mark,
    are you trying to use the "MorphOS Reg Tool" in the Tools directory, or use the register option from in the "Ambient> About MorphOS" menu option requester to register MorphOS?
    If you are online then the program/menu option should automatically find the servers in question and is something that you should not really need to concern yourself about. As long as you provide valid information your details will be forwarded and you will get a confirmation email notification to confirm your request and offer you the option to register MorphOS.
    If your query relates to something else in the registration process then please explain in more detail.
    I see you have an additional thread open in the forum that is on the same subject, so please mark one as "(SOLVED) - Registration Issues" so then the other thread will be considered to be the active one. You as the originator of the thread ideally needs to mark it as such. Just type the words mentioned into the thread TITLE text input when you add any comment in the thread and that will let other users know which one to continue to view if they are interested in helping or reading any continued issues. 8-)
    MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
  • »27.10.24 - 03:38
