Posts: 1385 from 2010/1/6
First of all: MorphOS_3.17-hybrid.hdimg has to be
extracted to a USB-Stick - not only copied! OpenFirmware does'nt know anyhing about format of such images!
I extract it with Win32_Disk_imager (on a Wintel-PC, of course). You have to rename 3.17-hybrid.hdimg to 3.17-hybrid.img - otherwise Win32_Disk_imager won't recognice it.
After that you can boot EFIKA as you described above.
Be aware that booting from stick is slow and takes some time.....
[ Editiert durch Amigaharry2 26.02.2023 - 13:33 ]Peg2, 3xPowerMac G5, 2xPowerbookG4, 2x MacMiniG4, Efika (again), A3000T and life is never boring.....
