Please help with USB Boot Problem On PowerMac G5
    gevik
    Posts: 16 from 2022/11/29
    I cannot boot from usb on a PowerMac G5. After following the usb-boot instruction and entering
    boot usb2/disk@2:,\boot.img umsd0:morphos.iso<ENTER>
    When I hit enter then nothing happens. Is there a way I can diagnose this?
    Actually after hitting the enter, the cursor moves one position then nothing happens!
    Thanks.
  • »11.12.22 - 22:24
    Posts: 3278 from 2003/3/5
    Are you sure you've copied the boot.img from the mac_ppc64 directory on the ISO? You can likely simplify the command by booting:
    boot ud:,\boot.img bi umsd0:morphos.iso
    (I see you've also omitted 'bi' in the cmdline above)
  • »11.12.22 - 22:43
    gevik
    Yes. (it was a typo here) I did not forget the "bi".
  • »12.12.22 - 03:33
    Posts: 1353 from 2004/2/8
    What model of PowerMac G5 do you have?
    What graphics card do you use?
  • »12.12.22 - 06:46
    gevik
    I get: can't OPEN the DIR device
    Perhaps I did something wrong to the USB stick!
    Any ideas?
    jPV wrote:
    Can you list files on the USB stick?
  • »12.12.22 - 14:41
    Posts: 1372 from 2010/1/6
    In OF not readable USB-Stick. Do not use USB3-Sticks and not larger than 4GB!
  • »12.12.22 - 15:46
    gevik
    THANK YOU ALL. IT WORKED.
    WHAT DID NOT WORK:
    1. I formatted 4x USB sticks (1.0 and 2.0) with sizes between 1GB,2GB,8Gb,16GB on an Intel Mac and FAT32 partition. None of them worked!
    2. I created a 2GB partition on an external HD connected with USB 2.0. It did not work
    WHAT WORKED:
    1. I formatted a 4GB (USB 2.0) stick with Windows and FAT32. AND IT WORKED.
    MY NEXT STEP:
    Spend countless hours installing and perhaps even developing software for morphos.
  • »12.12.22 - 17:32
    tolkien
    Posts: 564 from 2013/5/29
    Nice.
    You can download this morphos pack or individual programs from morphos-storage.
    MorphOS is a great system to enjoy.
  • »12.12.22 - 20:08
