Can I change an application icon ?
    laios
    Posts: 12 from 2022/11/9
    My question is can I change the icon of a application ? e.g e-uae instead the dull generic saw with a red-white ball ? droping an icon in info window doesn't keep the change
  • »13.11.22 - 16:54
    Posts: 2541 from 2003/2/24
    That should work.
    a) does the icon appear in the information window after you dropped it there?
    b) are your sure neither the file or directory is write protected?
  • »13.11.22 - 16:59
    laios
    Kronos wrote:
    That should work.
    Thanks for help , from what I see no they are not protected the icon does show there but doesnt change the icon of the app . I managed droping an icon same name with the application .info in case of e-uae e-uae.info in the same folder with the application . That .info doesn't show in files even with ..show all , anyway that worked .
    [ Edited by laios 13.11.2022 - 20:08 ]
  • »13.11.22 - 17:07
