Hw to get rid of the boot-disk icon and others on Ambient?
    Elowan
    Posts: 214 from 2011/4/18
    hi,
    I would like to "get rid" of some icons on my Ambient-desktop:
    "boot - hdd"
    "My Morphos"
    How can I safely do this? Is there a way to just hide them?
    Cheers!
    12" ibook G4 1.33Ghz, 1.5GB RAM, ATI 9550 32MB, 16GB SSD, WiFi, BT, ComboDrive
  • »30.08.22 - 19:15
    Mozzerfan
    Posts: 105 from 2016/10/5
    For the "my morphos" icon: Uncheck "display my morphos icon" in ambient/miscellaneous settings
    For the boot disk, i believe you can right click on it , and select put away.
  • »30.08.22 - 20:06
    Posts: 2220 from 2003/2/24
    Elowan wrote:
    "boot - hdd"
    If you mean the Boot partition which contains boot.img etc, it doesn't need to be mounted at all in the normal use. If you dare to edit HD settings, you can disable the "Automatically mount partition" option from it with the HDConfig tool. Open firmware can load files from the partition without it being mounted in MorphOS, and MorphOS installer/updater mounts it automatically, so it doesn't affect to future updates either.
  • »31.08.22 - 04:21
    Elowan
    ok, great! this worked out good so far.
    and yes, "boot-hdd" was the 128MB start-partition ;)
    Now, another question regarding Desktop icons, is there a way to disable the gauge?
    I mean the bar that indicates how much space is left/taken on a drive or Rma, etc?
  • »31.08.22 - 10:14
    Mozzerfan
    In ambient settings/icon display change Drive info to text.
  • »31.08.22 - 10:20
    Elowan
    found it ;)
  • »31.08.22 - 10:22
    Elowan
    Thank you :)
  • »31.08.22 - 12:57
    Elowan
    /SOLVED
  • »03.09.22 - 09:37
    Elowan
    SOLVED
  • »15.09.22 - 13:39
