Can you change the top-bar of Ambient?
    Elowan
    Posts: 214 from 2011/4/18
    hello,
    I like to change the very top menu bar of Ambient. In fact, I´d like to make it a bit more slim
    and maybe change the MorphOS logo for something else.
    (Actually, I use the "FourOne" skin and "OS41FEish" MUI settings)
    Maybe I can just swap some Images or something in a certain folder?`
    Has somebody an idea, what folder(s) this could involve?
    Cheers!
    12" ibook G4 1.33Ghz, 1.5GB RAM, ATI 9550 32MB, 16GB SSD, WiFi, BT, ComboDrive
  • »03.09.22 - 12:19
    Posts: 2220 from 2003/2/24
    The logo file is SYS:Prefs/Skins/FourOne/30/STitleBarObject
    Some skins have different height options by having separate dirs, but I can't remember how these are picked in use... FourOne has that "30" for graphics in 30 pixels height, but some others have something like 20, 22, 24, etc.
  • »03.09.22 - 15:20
    Elowan
    thanks again, will give this a try!
  • »09.09.22 - 15:42
