How to change folder-icons (globally)?
    Elowan
    Posts: 214 from 2011/4/18
    hello,
    I made good progress by tweaking the UI to my likings - thanks to the excellent advice on this forums.
    Now, I got another thing, I´d like to change:
    How can I permanently change the "default folder icon"? (like when you create a new drawer/folder)
    Is there a way to globally change all existing and future "default folders" to the new icon?
    Cheers!
    12" ibook G4 1.33Ghz, 1.5GB RAM, ATI 9550 32MB, 16GB SSD, WiFi, BT, ComboDrive
  • »03.09.22 - 12:16
    Posts: 2220 from 2003/2/24
    You can change default icons in SYS:Prefs/Presets/Deficons/ (SYS:Prefs/Presets/Deficons/def_drawer.info for the "folder icon").
    The path can also be changed from "Ambient Settings -> Miscellaneous -> Default Icons" if you want to make different setups...
  • »03.09.22 - 15:25
    Elowan
    thanks jPV - will try this
  • »09.09.22 - 15:42
