Posts: 668 from 2010/2/10
Quote:retrolinuz a écrit :
takemehomegrandma wrote:
Try renaming the .img file to .iso. If the img-file is uncompressed, this ”conversion” will work just fine!
Unfortunately it didn't work. :)
@beworld, I am not sure how I can convince you that my problem is with .img images, not the .bin ones. :) bchunk converts bin to iso perfectly well.
maybe your img file is unsupported support...
I test bchunk with img/.cue files and seem working here...
https://ibb.co/PgZwZC7
Next you cant test this, i build it quickly :
https://www.morphos-storage.net/upload/test/cc2iso-0.3.lha
You can find bin into src directory (cc2iso)
