USB-AUDIO stick
    Posts: 158 from 2019/4/6
    Hello,
    I have a question about a USB-AUDIO stick for morphos
    the USB-AUDIO stick is this:
    https://tinyurl.com/3r2c7tcj
    I have read that this AUDIO-USB stick is recognized by morphos since version 3.11
    even using real hardware for morphos
    i like to do my experiments
    in this case using qemu
    I can mount USB devices such as a flash drive as a host
    I wanted to ask if I buy this device can I enable the audio in morphos?
    once the USB-AUDIO stick is mounted
    morphos is able to recognize it as it would on real hardware.
    Thanks for any suggestions.
    here is a short video if it can serve to explain me better:
    https://www.youtube.com/watch?v=VoIET3UrLBo
    [ Edited by white 06.08.2021 - 21:04 ]
  • »06.08.21 - 17:00
    Tcheko
    Posts: 543 from 2003/2/25
    If this USB device is an audio class one, it should work ok.
    Regards,
    Tcheko
  • »07.08.21 - 06:33
    cip060
    Posts: 149 from 2010/7/30
    Paolo questa va di sicuro su morphos come scheda audio
    https://www.amazon.it/dp/B00IRVQ0F8/?coliid=I3U6ILOVFE0XUC&colid=2X633OERNDLVH&psc=1&ref_=lv_ov_lig_dp_it_im
    la possiede uno del gruppo whats up e me l'ha consifgliata lui per i lmac con chip non supportata
  • »07.08.21 - 07:59
    Posts: 3311 from 2003/3/5
    I doubt you'll have much luck with the device in QEmu. It should work on real hw though.
  • »07.08.21 - 10:04
    @jacadcaps
    @Tcheko
    @cip060
    Thanks very much for the replies.
    I tried to have the audio-video capture card recognized to see if the USB HUB was recognized.
    Obviously the acquisition card is not recognized but it is normal.
    Even connecting it to the PowerBook I get the same.
    Instead, the qemu USB HUB and the possible addition of the USB-AUDIO device are recognized
    I apologize for the length of the log output
    From the Morphos shell:
    USBDevLister:
    I am not able to read this correctly and understand if it can work but in the end it is a few euros of USB-AUDIO card
    maybe it is useful.
    In the end it is just curiosity should be tested with a real USB-AUDIO.
    Sorry again for the strange request.
    USBDevLister:
    Skipping 'PCI Root Hub Unit 0-0000-0000-n/a-00' (use SHOWROOT to list)
    Poseidon DevID : 'QEMU USB Keyboard-0627-0001-68284-pci.2:0d.0-1-00'
    Product Name : 'QEMU USB Keyboard' (ID: 0001, Vers: 0000)
    Manufacturer : 'QEMU' (Vendor: 0627 (unknown))
    Serial Number : '68284-pci.2:0d.0-1' (USBVers: 0200)
    Device State : fullspeed connected hasaddress hasdevdesc configured
    Device Address : 2 (Port 1 at PCI Root Hub Unit 0)
    Class/Sub/Proto : 0/0/0 (<unknown>)
    MaxPktSize EP 0 : 8
    Power Check : Supply = 500mA, Drain = 100mA
    Current Language: English (United States)
    Supported Langs : English (United States)
    1 configuration(s):
    · Config 1 (HID Keyboard)
    Attrs : bus-powered remote-wakeup
    MaxPower: 100 mA
    1 interface(s) for this config:
    · Interface 0 (HID interface (0)) (ID: '00-00-03-01-01')
    Alternate Setting: 0
    Class/Sub/Proto : 3/1/1 (HID (Keyboard))
    This interface is bound to hid.class, context 140CD724.
    1 endpoint(s) for this interface:
    · Endpoint 1 (interrupt <-[ IN)
    MaxPktSize: 8
    Interval : 10 ms
    No alternate settings.
    Standard Descriptors:
    Desc. 01 (Device), 18 bytes
    Desc. 02 (Configuration), 9 bytes (Config 1)
    Desc. 04 (Interface), 9 bytes (Iface 0/0, Cfg 1)
    Desc. 21 (HID), 9 bytes (Iface 0/0, Cfg 1)
    00: 09 21 11 01 00 01 22 3F 00
    Desc. 05 (Endpoint), 7 bytes (EP 1, IF 0/0, Cfg 1)
    Google: http://www.google.com/search?q=usb+0x0627+0x0001
    Poseidon DevID : 'QEMU USB Mouse-0627-0001-89126-pci.2:0d.0-2-00'
    Product Name : 'QEMU USB Mouse' (ID: 0001, Vers: 0000)
    Serial Number : '89126-pci.2:0d.0-2' (USBVers: 0200)
    Device Address : 3 (Port 2 at PCI Root Hub Unit 0)
    MaxPktSize EP 0 : 8
    1 configuration(s):
    · Config 1 (HID Mouse)
    MaxPower: 100 mA
    · Interface 0 (HID interface (0)) (ID: '00-00-03-01-02')
    Class/Sub/Proto : 3/1/2 (HID (Mouse))
    This interface is bound to hid.class, context 1415F64C.
    MaxPktSize: 4
    Interval : 10 ms
    00: 09 21 01 00 00 01 22 34 00
    Poseidon DevID : 'QEMU USB Hub-0409-55AA-314159-pci.2:0d.0-3-00'
    Product Name : 'QEMU USB Hub' (ID: 55AA, Vers: 0101)
    Manufacturer : 'QEMU' (Vendor: 0409 (NEC Corp.))
    Serial Number : '314159-pci.2:0d.0-3' (USBVers: 0110)
    Device Address : 4 (Port 3 at PCI Root Hub Unit 0)
    Class/Sub/Proto : 9/0/0 (Hub)
    MaxPktSize EP 0 : 8
    Power Check : Supply = 500mA, Drain = 0mA
    This device is bound to hub.class, context 14156E2C.
    1 configuration(s):
    · Config 1 (Configuration 1)
    Attrs : self-powered remote-wakeup
    MaxPower: 0 mA
    · Interface 0 (Hub interface (0)) (ID: '00-00-09-00-00')
    MaxPktSize: 2
    Interval : 255 ms
    Google: http://www.google.com/search?q=usb+0x0409+0x55AA
    Poseidon DevID : 'QEMU USB Audio-46F4-0002-1-pci.2:0d.0-3.2-00'
    Product Name : 'QEMU USB Audio' (ID: 0002, Vers: 0000)
    Manufacturer : 'QEMU' (Vendor: 46F4 (unknown))
    Serial Number : '1-pci.2:0d.0-3.2' (USBVers: 0100)
    Device Address : 5 (Port 2 at QEMU USB Hub)
    MaxPktSize EP 0 : 64
    Power Check : Supply = 100mA, Drain = 0mA
    1 configuration(s):
    · Config 1 (Audio Configuration)
    MaxPower: 100 mA
    2 interface(s) for this config:
    · Interface 0 (Audio Device) (ID: '00-00-01-01-04')
    Class/Sub/Proto : 1/1/4 (Audio Control)
    This interface is bound to usbaudio.class, context 14A7041C.
    0 endpoint(s) for this interface:
    · Interface 1 (Audio Output - Disabled) (ID: '01-00-01-02-00')
    Class/Sub/Proto : 1/2/0 (Audio Streaming)
    Alternate settings:
    · Interface 1 (Audio Output - 48 kHz Stereo) (ID: '01-01-01-02-00')
    Alternate Setting: 1
    · Endpoint 1 (isochronous OUT ]->)
    MaxPktSize: 192
    Interval : 1 ms
    SyncType : synchronous
    UsageType : data
    Desc. 24 (Audio Control Header), 9 bytes (Iface 0/0, Cfg 1)
    00: 09 24 01 00 01 2B 00 01 01
    Desc. 24 (Audio Input Terminal), 12 bytes (Iface 0/0, Cfg 1)
    00: 0C 24 02 01 01 01 00 02 03 00 00 06
    Desc. 24 (Audio Feature Unit), 13 bytes (Iface 0/0, Cfg 1)
    00: 0D 24 06 02 01 02 01 00 02 00 02 00 07
    Desc. 24 (Audio Output Terminal), 9 bytes (Iface 0/0, Cfg 1)
    00: 09 24 03 03 01 03 00 02 08
    Desc. 04 (Interface), 9 bytes (Iface 1/0, Cfg 1)
    Desc. 04 (Interface), 9 bytes (Iface 1/1, Cfg 1)
    Desc. 24 (Audio Stream General), 7 bytes (Iface 1/1, Cfg 1)
    00: 07 24 01 01 00 01 00
    Desc. 24 (Audio Stream Format Type), 11 bytes (Iface 1/1, Cfg 1)
    00: 0B 24 02 01 02 02 10 01 80 BB 00
    Desc. 05 (Endpoint), 9 bytes (EP 1, IF 1/1, Cfg 1)
    Desc. 25 (Audio Generic Endpoint), 7 bytes (EP 1, IF 1/1, Cfg 1)
    00: 07 25 01 00 00 00 00
    Google: http://www.google.com/search?q=usb+0x46F4+0x0002
    Thank you.
  • »07.08.21 - 11:39
