MorphOS Developer
Posts: 3311 from 2003/3/5
Is this some sort of a limitation of the non-registered version of morphos.
No, the driver isn't perfect, but what you're describing sounds more like an issue with your Wifi access point - I've seen a lot of problems especially with the more modern one. If you have some 15 year old router lying around, try setting up a separate Wifi network just for your PowerBook on that. That's what I did and it works way better than when I connect right to my 5 year old router.
[ Edited by jacadcaps 16.05.2021 - 15:40 ]
