Dual boot on X5000
    Posts: 2 from 2021/4/2
    Hey!
    I tested MorphOS on my X5000 through the live DVD and I am really impressed.
    (OK, 90% of that is because of the new WayFarer browser, but still ...)
    I want to install it and get a proper license, but I also want to keep my OS4.
    How would I setup a dual boot system?
    Is it just a matter of popping in another SSD and hope that I select the right one while installing, or do I have to switch the drive (or the cable) every time I want to switch OS?
  • »02.04.21 - 12:18
    Posts: 12556 from 2003/5/22
    > I also want to keep my OS4. How would I setup a dual boot system?
    Using a separate drive for each OS is the safe way to go. In theory, even installing both to separate partitions on the same drive should be possible*, but doesn't seem to go as smoothly in practice.
    * Edit: https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=13611&forum=3&start=9
    [ Edited by Andreas_Wolf 28.07.2023 - 13:47 ]
  • »02.04.21 - 16:28
    Posts: 1932 from 2003/10/19
    Steffest wrote:
    Hey!
    I use two drives myself. I am stuck with a GPU that only works with OS4 and one that only works with MorphOS, so I dont use MorphOS much on mine. I prefer the G5 machine. What GPU are you using to support them both? I am still looking for a good solution that will run them both well.
  • »05.04.21 - 10:32
    discreetfx
    Posts: 403 from 2003/7/26
    You could do like me and get and external enclosure with GPU and a really big hot wired external switch.
    https://preview.ibb.co/ia5WwR/6548f64c_6409_4e20_95db_c01c2a7db0ee.jpg
    Just kidding, I’ve never found a way to do this.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »05.04.21 - 19:40
