Toolbar
    Goodman
    Posts: 115 from 2006/8/2
    Hi guys,
    I've reinstall Morphos from scratch but I don't remember how to open that classic menu which stay on the bottom. May someone help me?
  • »14.03.21 - 07:54
    Chain-Q
    Posts: 350 from 2003/10/12
    If you mean the "Dock"-like icon bar, it's called a "Panel" in Ambient. So go to Ambient Settings, select "Panels" click on "New Panel". A small gray area with an arrow icon will appear, which is the collapse gadget for your new panel. Otherwise it will be empty.
    You can then either edit the Panel from the Settings window there, or by right clicking on it, and use the context menus, and by drag & drop.
    [.Hosting AmigaSpirit.hu.]
  • »14.03.21 - 08:03
    Goodman
    Thanks for reminding me.
  • »15.03.21 - 18:27
