Firmwareupdate for Pegasos1?
    Posts: 4 from 2020/10/15
    Recently, I found a Pegasos1-System and I tried to start it up or give MorphOS 3.14 a chance.
    The OF says it is version 01.b114 whereas I found a info that there is a version 0.1b131 (20030805144022) available.
    Does someone know how to get that firmware ???
    Regards,
    Sven
  • »15.10.20 - 13:37
    Posts: 3311 from 2003/3/5
    Any particular problems you'd like to address by changing firmware? Unless you really think it's going to fix some issue, I don't think it's worth the risk.
  • »15.10.20 - 14:01
    I have indeed several problems.
    The whole thing is very unstable:
    I burned a CD with MorphOS 3.14 in order to install it but I can't even boot it up as the SmartFirmWare always complains about differnt things:
    - there is no file format found
    - the bootpeg1.img has unknown format
    - the directory can not be read
    I did the following to solve that problem:
    - tried 3 different CD/DVd-drives
    - tried with both IDE-connectors on mainboard
    - tried with different cables (80 lines)
    - tried with HD/DVD on different/same cables
    - tried with different CDs
    It stays all the same:
    I go to console, type
    ls /pci/ide/cd
    and get the directory (in most of the cases).
    After typing
    boot /pci/ide/cd bootpeg1.img
    I get always the error
    error: no filesystem recognized
    [ Editiert durch honitos 16.10.2020 - 08:39 ]
  • »16.10.20 - 05:38
  • ASiegel
    Posts: 1396 from 2003/2/15
    Have you tried switching up the slave or master modes of your CD drive? If I remember correctly, I connected the CD drive to the secondary IDE port and used it in master mode. Using any of the other modes (slave/auto) caused issues.
    Just switching IDE ports may not be enough.
  • »16.10.20 - 06:57
    _coliN_
    Posts: 70 from 2003/4/30
    Hello!
    After your post with your problems, I started a quick try to boot 3.14 on my Pegasos I.
    I dont know the exact firmware version, but I have 1 GB RAM, and use a Harddisk and a DVD on the first IDE, and a DVD-writer on the secondary IDE. I booted successful the new MorphOS 3.14 with this setup. Tomorrow I will install, and look forward to give Wayfarer a try...;)
    My command is every time the same, when I have to boot a update CD:
    Boot /pci/ide/cd@1,0 bootpeg1.img
    To say only /ide/cd as argument never worked for me in the past...
    Good luck!
    Bo
  • »17.10.20 - 16:16
    Crumb
    Posts: 736 from 2003/2/24
    honitos wrote:
    Regards,
    Sven
    IIRC preapril-peg1 refused to init Radeon9250 agp cards and usb didn't work correctly until firmware was updated. It would be interesting to know what 0.1b131 fixed
  • »20.10.20 - 06:17
    _coliN_ schrieb:
    Hello!
    Good luck!
    Bo
    Hi _coliN_:
    thanks for your reply.
    Finally I found a way to boot.
    Because the OFW always complaint about "no filesystem recognized" when I tried to
    boot /pci/ide/cd@...
    I did the following (glad to found an old MorphOS 3.8 installation in disk):
    I booted from disk, copied "bootpeg1.img" to disk, rebooted into OFW and
    boot /pci/ide/disk@0,1:0 bootpeg1.img !
    I did an upgrade and have a completed MorphOS 3.14 installation so far...
    But I have to say that OFW/Pegasos1-system is just a big piece of rubbish.
    I could "ls" the cd, but when trying to boot, it always complaint about "no filesystem recognized"...
  • »23.10.20 - 09:42
    Crumb schrieb:
    honitos wrote:
    Regards,
    Sven
    Meanwhile I managed to do an upgrade, because I found an older Installation of MorphOS.
    But still I cannot boot from CD...
    If found the firmwareinfo here: https://de.wikipedia.org/wiki/Pegasos_(Computer)#Firmware
    But no clue about a downloadsite...
  • »23.10.20 - 09:46
    judas
    Posts: 175 from 2005/1/14
    I have firmware .b124 for Peg1, which can be flashed.
    I'm also willing to try b131, if i can get it somewehere.
  • »23.10.20 - 16:30
