Posts: 2217 from 2003/2/24
robbhar wrote:
I did find the googleaccountfix.js on warmup so I can try that if I ever got to a booted up 3.12.
No need to download it elsewhere, it already comes bundled with MorphOS 3.12. Just open the Scripts window in OWB and click Add to select the script. Restart OWB to take the new script(s) in use.
Are there other key presses I can try during bootup?
The Shift key should take you into a graphical MorphOS boot menu where you can also select few different standard screenmodes. If you have difficulties to get anything work by pressing the keys, you could also try to activate this bootmenu by booting from the Open Firmware prompt. See the instructions here:
Boot ArgumentsQuote:
Also since on one machine I don't want to loos my 3.11 files, does this page still show true for how to upgrade MorphOS
The Update option in the MorphOS installer has worked very well always. It doesn't matter if you do it easy way by booting from the CD or little more harder (but faster filecopying) way by booting from the ISO file, which ever way you want (or works for you) until you use the official installer and select the Update option there.
