License Key
    MoerBoer
    Posts: 239 from 2019/10/15
    I'm strongly considering purchasing a license for MorphOS.
    I've read the website and I can't seem to get an answer for this.
    When buying a license, is it locked to that version of MorphOS ( i.e. 3.12 ), or will it be usable for future releases and for how many versions?
    Thanks.
  • »17.10.19 - 17:55
    emeck
    Posts: 175 from 2014/7/15
    It is locked to the hardware for which you bought the license, not to the OS version.
    I have my key since MOS 3.8 if I remember right, and have installed every upgrade released, so 4 times. Always free!
    Correction, bought my first key for MOS 3.6 so 6 free upgrades since then.
    [ Edited by emeck 17.10.2019 - 22:12 ]
    PowerBook 5.8 MorphOS 3.18
    Mac Mini MorphOS 3.18
  • »17.10.19 - 18:09
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    The key is locked to the hardware, but you get future updates for free. If your hardware fails you can transfer it to a new machine.
    I'm in the boat since MorphOS 3.8 (I think?) with a PowerBook G4 5,4. This one broke so my key was kindly transfered to a new PowerBook G4 5,8 which I am running now. All the same license up to 3.12 now.
  • »17.10.19 - 18:12
    Posts: 1385 from 2010/1/6
    My Pegasos-key is from MOS 2.0.........
    I think that we have to pay at the next major-release - e.g. switching to new platform (MOS 4.x?)
  • »17.10.19 - 18:44
    Posts: 2217 from 2003/2/24
    My too, and all those updates have been free during over 10 years.
    Isn't that natural without changing the licencing scheme? :) It happens with the current scheme if you change the machine, so platform change makes you to buy a new licence anyway.
  • »18.10.19 - 02:55
    MoerBoer
    Thanks all.
    Just a final question, is the license created as a "snapshot" of the machine as it is right now?
    If I decide to add more RAM or swap out the HDD for a SSD, will I require a new key?
  • »18.10.19 - 04:31
    Posts: 2564 from 2003/2/24
    Licence is tied to the MAC address of the motherboard nic, so you can change/upgrade any other part of the computer without issue.
    @AmigaHarry
    If MorphOS4.0/NG/64 is released for PPC too (which I expect) it's very likely that any 3.x key would still be valid (AFAIK there are no 64bit systems that could have been registered before 3.0).
    [ Edited by Kronos 18.10.2019 - 08:41 ]
  • »18.10.19 - 04:39
    MoerBoer
    Thanks Kronos, and if it wasn't for you posting on MacRumors, I would not have known that my iMac G5 was supported in the new 3.12 :)
  • »18.10.19 - 04:58
    Posts: 1090 from 2004/9/23
    So, Kronos did something useful. Thats a first :D
  • »18.10.19 - 07:14
