Powerbook 1.67 DLSD
    Posts: 27 from 2019/10/6
    As this model is the only Powerbook with automatic CPU frequency scaling what are the correct preferences to use in settings?
  • »07.10.19 - 20:15
    Posts: 3278 from 2003/3/5
    You don't need to tweak anything really. The only thing that's in settings is the ability to disable full speed.
  • »08.10.19 - 04:18
    I ask because running a classic Amiga app, Protracker, in E-UAE, the playback speed goes from normal as expected, to a slow crawl - as if the CPU has scaled back and the internal timing has gone wrong.
  • »08.10.19 - 05:44
    Interesting. I'll have a look at this in the evening.
  • »08.10.19 - 05:50
    I've installed a newer version of e-uae and tweaked the config file - I've haven't seen the same slowdown since.
  • »08.10.19 - 14:04
