Noob questions
    Roland
    Posts: 36 from 2013/2/10
    Hi all,
    I just installed to 3.10 (good to see its still alive). Questions are
    - Is magicMenu integrated or do I need to install it? If integrated where?
    - I saw some cool screenshots of 3.10 of flat themes on the forum. After installation, I only have a few window decorations but still old icons. How/where do I set them up?
    Thanks all and have a nice day!
  • »31.03.18 - 17:36
    Posts: 2564 from 2003/2/24
    - Prefs->System->Input-> "Show menus under mouse"
    - Prefs->Screens->"Ambient"->Edit-> try out the skins listed
    As for the icons, I think there is an icon pack somewhere, but I can't help you here atm
  • »31.03.18 - 17:48
    Roland
    Thanks, found the skins section under ambient. Perhaps Skins should be renamed to Decorations.
    A skin is about the complete look and feel (backdrops/icons/window decorations).
    Cheers
  • »31.03.18 - 17:52
    asrael22
    Posts: 445 from 2014/6/11
    Why? A skin is a skin.
    How you make your hair or which shoes you wear is another matter.
    Manfred
  • »31.03.18 - 18:15
  • ASiegel
    Posts: 1396 from 2003/2/15
    You might also want to open MUI Prefs and click on the "Settings" button in the upper left corner. This will open a menu that allows to choose between various included presets. Make sure to press "save" if you have found settings that you would like to keep.
  • »31.03.18 - 18:18
    Roland
    Thanks! Didn't find that one yet.
  • »01.04.18 - 05:41
  • ASiegel
    We should definitely have an article about it in our virtual MorphOS Library.
  • »01.04.18 - 06:04
