Right Click, PowerBook
    lerche
    Posts: 14 from 2004/7/25
    How do i do Right Click to acces menu bar on PowerBook G4 running Morph OS 3.9 ?
    Using a 2 buttons mice i works fine but is there no way doing Right Click without mice...
    Best regards
    Henry Lerche Rasmussen
    Denmark
  • »11.02.17 - 06:22
    tolkien
    Posts: 585 from 2013/5/29
    Try doing it with two fingers...really.
  • »11.02.17 - 06:56
    Posts: 1360 from 2004/2/8
    It depends on a PowerMac model you have. If its touchpad does support multitouch then Right Click is archieved with two point touch of the touchpad. If it doesn't (earlier PowerBooks)... well, there's always Right Amiga+Right Alt way - or a two button mouse, sadly.
  • »11.02.17 - 07:50
