Set MorphOS as boot drive from OS X?
    Alexco
    Posts: 36 from 2015/5/16
    I have a dual boot setup with OS X on my G4 DA which uses a small 64MB HFS boot partition for MOS. So far I was not able to select this boot partition with the OS X select boot drive dialog in the system preferences.
    Is this somehow possible? Or do I always need to use the alt key during boot?
    Thanks,
    Alexander
  • »08.05.16 - 18:30
    Posts: 2541 from 2003/2/24
    You can allways set MorphOS as default in OF to avoid having to pres ALT.
    Look here
  • »08.05.16 - 18:48
    Alexco
    I know that I can use OF to set the boot device. But as of now, I still use OS X as main OS on this box. And now I search a quick way to boot into MOS.
  • »13.05.16 - 16:56
    Posts: 1932 from 2003/10/19
    Holding down option at Boot is the only way I know of doing it if you don't use the OF option.
  • »13.05.16 - 17:41
    Posts: 3278 from 2003/3/5
    Hold the alt key on boot. The menu will be available quicker if you set the net-boot? setting in OF to false.
  • »13.05.16 - 17:49
